Problem
Old Jan 1, 2009 | 10:30 PM
1slow67's Avatar
1slow67
ROTM Moderator
Smell it out of the exhaust. Also when car turned off you could smell the fumes from the engine bay. Sometimes my plugs would have some gas on them also.
Old Jan 1, 2009 | 10:34 PM
Gun Jam's Avatar
Gun Jam
My only suggestion is to set timing at 12 deg adv at idle...when you rev the engine it should move to around 30ish i think.
are you sure your damper wheel has only 1 timing mark on it?
something is way off...it could be rich too...try to set timing to 12 at idle ...then see what it does
-Gun
Old Jan 1, 2009 | 10:36 PM
1slow67's Avatar
1slow67
ROTM Moderator
Ok I will do that tomorrow. I only saw one mark on this one when I put it in.
Old Jan 1, 2009 | 11:54 PM
racin66coupe's Avatar
racin66coupe
is it vac advance? if so, it really only matters at idle cause itll do its own thing cause it advances itslef
Old Jan 1, 2009 | 11:58 PM
1slow67's Avatar
1slow67
ROTM Moderator
It is spark advace, but it doesn't work. It has no vacuum for some reason.
Old Jan 2, 2009 | 12:01 AM
racin66coupe
odd.... i have no clue then bud, sorry
Old Jan 2, 2009 | 12:03 AM
1slow67's Avatar
1slow67
ROTM Moderator
Spark advance dizzy with a vacuum advance carb. But vacuum doesn't work on dizzy.
Old Jan 2, 2009 | 08:51 PM
Gun Jam's Avatar
Gun Jam
could you explain spark adv?
I know of vac and mechanical advance that using rotation speed.
-Gun
Old Jan 2, 2009 | 09:49 PM
1slow67's Avatar
1slow67
ROTM Moderator
-Gun
I really don't know anything about spark advance, just know the dizzy has that instead of vacuum.
Old Jan 2, 2009 | 09:56 PM
1slow67's Avatar
1slow67
ROTM Moderator
I found this pdf about it.
http://www.autoshop101.com/forms/h59.pdf
