Problem
Old Jan 2, 2009 | 10:09 PM
  #21
Gun Jam's Avatar
Gun Jam
dude and ECM?
Thats either a computer or and electronic counter measure...the latter would be more preferable in my book.
either way your on your own here...sorry m8.
Hopefully someone else can help...
where did you scare that thing up? why the hell would you want that?
happy hunting
-Gun
Old Jan 2, 2009 | 10:21 PM
  #22
1slow67's Avatar
1slow67
ROTM Moderator
Hopefully I will figure this engine out soon. Probably buy a new dizzy after my birthday.
Old Jan 3, 2009 | 03:16 PM
  #23
BigIron22's Avatar
BigIron22
that pdf is for a toyota? do you have fuel injection.
Old Jan 3, 2009 | 03:20 PM
  #24
1slow67's Avatar
1slow67
ROTM Moderator
No. I didn't read all of the pdf. I just looked at the first paragraph.
Well I lowered the fuel down and it is running better lag is almost completely gone. I was at almost 5 turns and now I am at 3.
Old Jan 3, 2009 | 07:44 PM
  #25
1965fastback's Avatar
1965fastback
The best way to set idle is with a vacuum gauge. For a 200 you should pull around 19-20 inches of vac. You can also set timing this way, adjust the timing until it pulls 19-20 inches and runs smooth.
Old Jan 3, 2009 | 08:05 PM
  #26
1slow67's Avatar
1slow67
ROTM Moderator
I am probably going to buy a new dizzy. I have around 30 to spend. I just need to find one on ebay. Need one since my vacuum doesn't work.
Timing is now set a 16 degrees and the mixture is down to 2 1/4 or so.
Old Jan 3, 2009 | 09:20 PM
  #27
Gun Jam's Avatar
Gun Jam
when you rev the engine up do you see the timing advance?
How far does it advance?
-Gun
Old Jan 3, 2009 | 10:49 PM
  #28
1slow67's Avatar
1slow67
ROTM Moderator
I think it went over 32 degrees. My grandfather was watching that while I revved it.
Old Jan 3, 2009 | 11:26 PM
  #29
Gun Jam's Avatar
Gun Jam
that sounds reasonable...timing should be pretty close now i would think
-Gun
Old Jan 4, 2009 | 12:07 AM
  #30
dterry68's Avatar
dterry68
your ignition timing should be set at about 12 on a manual inline six.
