tranny slipping
Old Jan 2, 2009 | 08:12 AM
chappys4life's Avatar
chappys4life
Default tranny slipping
In the morning when first warming up my car if I put the car in drive too early it will just go into reverse occasionally. Once the car is warmed up no problems. Any thoughts on whats causing this?
Oh its a 289, 2v, c4, all stock.
Old Jan 2, 2009 | 09:27 AM
fakesnakes's Avatar
fakesnakes
Check your fluid level. When was the last time you changed the fluid?
Old Jan 2, 2009 | 11:55 AM
blue66mustang's Avatar
blue66mustang
There might be a problem with the torque converter draining back into the trans case overnight. I believe there is a checkball in the pump that controlls this.
FWIW.
Old Jan 5, 2009 | 09:11 AM
chappys4life
I am not sure the last time a fluid change was done. ( I have only had the car a few months). I will get new fluid and a filter though and change it. Any recommendations on type?
I was thinking torque converter too. The transmission was rebuilt in 03' (found a receipt in the glove box).
Old Jan 5, 2009 | 09:43 AM
Art Brock's Avatar
Art Brock
A few years ago I had an old Ford truck with a C-6 auto. When cold it would only go into Reverse, but after it warmed up a little while it would shift fine like it should.
I changed the tranny filter & fluid and the problem went away.
Old Jan 5, 2009 | 10:54 AM
urban_cowboy's Avatar
urban_cowboy
You should use F-Type ATF or something compatible if it is a 3 speed C4 or C6. AOD or EAOD will require something in the Mercron/Dextron rating.
TCStangerv6
Oct 11, 2015 05:57 PM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 8, 2015 11:50 AM
