Who has 17s on their 69-70?
Old 02-14-2009, 10:08 AM
  #41
boogerschnot
boogerschnot's Avatar
Pics!!! That sounds great man. Make a new thread to show them off.. I would go with at least a 1 inch spacer in the rear to bring it out a little.
boogerschnot is offline
  #42
69mach1377
69mach1377's Avatar
I'll try to post a pic today.
BTW, the front adapters cost $60 on ebay and the longer rear studs were $20 at autozone.
1" more in the rear will get me in the same predicament I was in before with 275s. I'm trying to center the meat between all obstacles.
69mach1377 is offline
Old 02-14-2009, 10:10 AM
  #43
boogerschnot
Why change the fronts to 235's ? Why not just leave the 245's? I have 235 45's up front and I think they look a little wimpy.. Just a thought. Especially if you are with 275 40's in the rear , they should sit at about the same height.
Old 02-14-2009, 10:12 AM
  #44
boogerschnot
OH,, you bought studs instead of a bolt on spacer.. I see. Well if you get a bolt on spacer you may need to go back to the old studs in the rear because the long lugs may not fit with the wheel on the spacer.
Old 02-14-2009, 11:20 AM
  #45
69mach1377
69mach1377's Avatar
I will not get a bolt on spacers for the rear for reasons stated earlier. On the front, since I have manual R&P, skinnier tires are easier to turn in the parking lot. I do appreciate your thoughts.
How wide are your rears booger?
Old 02-14-2009, 02:22 PM
  #46
69mach1377
69mach1377's Avatar
Okay, 3 pics up here;
http://photobucket.com/albums/v618/danaranda/69stang
Old 02-14-2009, 10:43 PM
  #47
boogerschnot
I have the stock 2005 : 235-55's on the rear and 235-45's up front.. The fronts were too tall and would hit the valance so I went to the 45's
Old 02-14-2009, 10:56 PM
  #48
boogerschnot
I thought that I should add that when I was trying out new wheels, a bud let me borrow his 0 offset 17x8.5's with 275-40 Gforce goodrich tires and it fit perfect in the rear end.. There is a pic of that on dodgestangs site.. The car was green then..
Old 03-01-2009, 09:12 AM
  #49
69mach1377
69mach1377's Avatar
You might be right about the 235s...245s would look better up front. The 245s there now don't seem to be too hard to crank going slow. I had 225s that were track tires and they were pretty hard to turn in a parking lot.
I'm also thinking that I can fit 285/40/17s in the rear. Taking measurements this weekend.
BTW, I found this great site to help everyone figure out what fits based on differences of rims and tires;
http://www.rims-n-tires.com/rt_specs.jsp
Old 03-01-2009, 09:21 AM
  #50
Norm Peterson
Norm Peterson's Avatar
Be very careful how you use that calculator - it does NOT show that the tire section width varies as you change the wheel width. This may not matter if you're only making minor changes, but can be absolutely critical when you're trying to fit the widest (or maybe tallest) tire on a wider rim.
The correction is to add 0.4" (10 mm) to the tire section width for every inch wider the wheel is from the "measuring rim" width (that you can find at TireRack.com or other tire sites).
I like the idea that people are willing to be helpful by providing these calculators. Too bad that most of them are technically incorrect.
Norm
Norm Peterson is offline
Quick Reply: Who has 17s on their 69-70?
