Shelby Drop?
This is the engine side of my 1966. see that set of holes just above the upper arm, those are the original mounting holes. The arm was lowered 1":
That is the Shelby drop. Here is a look from the other side without the spring in the way:
and thats it?
Remove Spring
unbolt UCA
Drill Holes
Bolt in UCA
Reassmble
right?
i might do this while i have the bay stripped, even if i don't put the control arm in the new holes right away.
do i need special springs?
and does the rear need lowered or do mideye leafs drop it enough?
one last thing, before and after pics of drop?
Remove Spring
unbolt UCA
Drill Holes
Bolt in UCA
Reassmble
right?
