Spring Perch location on 69
Old Jan 8, 2009 | 12:26 PM
snorulz's Avatar
snorulz
Default Spring Perch location on 69
I have been doing some searching on my lunch break for the past couple days but can't find the information i am looking for on this site or others.
On a 69 mustang, if you place the spring perches on a set of saw horses, will the housing face where the 3rd member attaches be facing up at a 5 degree angle? I know it does for the 64.5-66 but what about a 69?
Also, the spring perches are mounted 43" center to center, correct? I am pretty sure i am correct but wanted to check anyway. I would hate to have them in the wrong spot after it is powder coated.
Old Jan 8, 2009 | 06:04 PM
baddog671's Avatar
baddog671
Luke, yes, 43" is the correct center span for the perches.
As for the other thing, I don't know for sure. My 9" is out of the car, so I can't be positive, but it looks like it is coming out straight, and not at an angle. However, 5* isn't much, and I might not be able to see that...
Old Jan 8, 2009 | 08:54 PM
snorulz's Avatar
snorulz
i asked Daze and he said he was 85% sure all mustangs had 5 degrees but not positive. When you look at his pictures it is really hard to tell there is any tilt. Do you happen to have an angle finder?
Old Jan 8, 2009 | 09:20 PM
baddog671's Avatar
baddog671
Earlier tonight I looked again out of curiosity. I made sure the perches looked as level as possible, and now maybe I see a slight upward angle. I don't have angle finder...
It would make sense though if it did have a slight upward angle, since the transmission is probably a few inches higher than the diff. center...
Old Jan 8, 2009 | 09:21 PM
snorulz's Avatar
snorulz
Thanks for your help. I will put them at 5 degrees unless someone steps in and says different.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
mungodrums
Sep 28, 2015 10:54 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
