351 swap
Old Jan 22, 2009 | 09:05 PM
JERM_1967stang's Avatar
JERM_1967stang
Default 351 swap
okay so i keep hearing about the 5.0 swap to make your car efi but i was thinking... yeah they have lot of potential but like the old saying there is no replacment for displacment. how well would a efi 351w fit in our cars?? like one from a first gen lightning? or a truck?? i know its set up for low end torque but with the right heads it would work... right?? is there any records of anyone doing this?? or is it even possible? is there a hood that fits other then like a 7" cowl??
opinions?
Old Jan 22, 2009 | 10:17 PM
gothand's Avatar
gothand
Don't know about the EFI with 351W, but prior to having the EFI 5.0L GT-40 engine, I had a built 351W in my '65 fastback. Besides the fact that it is VERY tight between the shock towers on a 65/66, with street tires, I couldn't put that much power to the ground with the 351W (394 ft-lb. @ 3000 rpm at the rear wheels).
Bottom line is that it sounds like a fun project on a '67 and up but not so much on a 65/66. For displacement and EFI, I'd probably go with the 331/347 instead due to the lighter weight, better fit (size) and availability of parts.
Old Jan 24, 2009 | 10:10 PM
ungaii102's Avatar
ungaii102
My 67 coupe has a 351 in it. It's not EFI but seems to fit pretty good. I bought it with the 351 in it so I don't even know if they did it right, or what they had to modify. It also has a FMX auto trans.
Old Jan 25, 2009 | 05:36 PM
LCC's Avatar
LCC
The work is the same for a 302 or a 351. The intake you choose will effect the hood clearance. Any upper intake for a 302 will fit a 351, the lower intake is the only difference. I had to put in a tear drop hood but my upper is a big "box" and wanted something different..
Old Jan 25, 2009 | 09:56 PM
andrewmp6's Avatar
andrewmp6
Lcc who made your intake?
Old Jan 25, 2009 | 11:00 PM
gothand's Avatar
gothand
Correct me if if I'm wrong LCC, but aren't those box intakes with short runners are more suited for supercharged vehicles such as your own (don't want any surprises most others who are naturally aspirated).
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
