Which Oil Would You Use?
Old Jan 25, 2009 | 12:06 AM
fakesnakes's Avatar
fakesnakes
Valvoline 10w-30 and then after about 2500 miles I switch to Mobile 1 10w-30.
Old Jan 25, 2009 | 01:08 AM
Starfury's Avatar
Starfury
No, I don't believe it does, my77. And for pete's sake, stop using pennzoil=/
Old Jan 25, 2009 | 01:40 AM
67fire's Avatar
67fire
Mobile 1
5W-30 in the winter and 15W-50 in the summer.
Eric
Old Jan 25, 2009 | 01:42 AM
dcohen's Avatar
dcohen
my engine shop recommended rotella T because it still has enough zinc to protect flat tappet cams
Old Jan 25, 2009 | 01:49 AM
Starfury's Avatar
Starfury
Not anymore it doesn't. Pretty much everything except Valvoline Fleet Guard and Napa's 15W40 (which is rebottled valvoline) are on API's CJ-4 spec, which means no more zinc.
Old Jan 25, 2009 | 09:31 AM
Oxnard Montalvo's Avatar
Oxnard Montalvo
There's a lot of information and confusion in the air over this issue. Bottom line is that if you've got flat lifters, you should have the zinc level at or above 1000ppm.
The oil companies don't really seem to be reacting all that forcefully with marketing high zinc content "off road" oils. It would be nice if they splashed the level across the label, or put a big old FLAT TAPPET COMPATIBLE on the bottle so dummies like me could figure which oil to use.
Here is a link to the Mobil 1 oils. (dated 11-08)
MOBIL 1 OILS
Old Jan 25, 2009 | 10:06 AM
Starfury's Avatar
Starfury
As a side-note, Valvoline's VR-1 is actually street legal, it's just not API certified. The zinc content is the same between the VR-1 and their "off road" racing oil (which I don't recommend outside of racing because it doesn't have much in the way of detergents and anti-corrosion agents).
Basically, if you see an "API Certified" logo on the bottle, it doesn't have any significant amount of zinc in it.
Old Jan 25, 2009 | 10:59 AM
my77stang's Avatar
my77stang
star, my whole family has used pennz since as long as i can remember and i can't recall a single engine failure that was oil related. got 365,000 miles from a 300 I6 using it and that was even with 4-5k change intervals. when it popped a head gasket (due to a popped radiator hose and being stuck in chicago traffic) we looked at the cylinders and you couldnt catch your fingernail on the ridge. inside of the motor was very clean too, the only reason you'll ever see a motor with build up is because people didn't change their oil on time.
not bad if you ask me.
Old Jan 25, 2009 | 11:21 AM
Starfury's Avatar
Starfury
Not true. I've heard several horror stories from several different racers (people I know personally, not on the forum), all the same. They had to run Pennzoil at the track because they had nothing else on hand, had crap for oil pressure by the end of the race, pulled the vc's and saw nothing but foamy sludge. Nobody I know will touch Pennzoil, including every racer and shop owner I talk to.
Aside from aeration problems, Pennzoil has a high paraffin content. Wax does not belong in your engine. That's what they use in 'lifter quiet' solutions to quiet down engines with excessive lifter tap, and exactly why I don't recommend using such products.
On top of that, both Pennzoil and Quaker state oils have a very high sulfer content. What happens when you mix sulfer and exhaust gases? You get sulpheric acid. Also not something you want in your crankcase.
Old Jan 25, 2009 | 01:24 PM
65Coupester's Avatar
65Coupester
You can also get zinc and phosphorus additives to cover the bases.
Here is one, there are a couple more.
http://www.zddplus.com/
