Pistons and Wrist Pins
Old Jan 26, 2009 | 09:38 AM
mstg007's Avatar
mstg007
Default Pistons and Wrist Pins
I have a cast iron, press, and I was wondering when I install new pistons on the connecting rods, What lubercation or oil do I use when I press the wrist pinn in the piston and connecting rods?
Thanks!
Old Jan 26, 2009 | 12:08 PM
ky's Avatar
ky
America ftw
just some castrol is fine
Old Jan 27, 2009 | 07:13 PM
mstg007's Avatar
mstg007
Help, I can not get the wrist pins to press out... Any ideas?
Old Jan 27, 2009 | 07:42 PM
my77stang's Avatar
my77stang
they should come out cold but are a biotch, if not you can try heating up the small end of the rod with a torch.
when you install the new ones, just heat up the small ends of the rods and slide the pins thru and then squirt a little oil on them. make sure you face the pistons the right way though, 4 1 way and 4 the other
Old Jan 27, 2009 | 07:47 PM
mstg007's Avatar
mstg007
lol... I forgot, I need to make sure that the connecting rod is facing the right direction linked with the piston....
Ok. I will try to get a torch!
Old Jan 27, 2009 | 08:48 PM
my77stang's Avatar
my77stang
yeah man, IIRC the numbers stamped on the rods/caps should all face out when installed in the motor
poke68
Dec 16, 2025 03:36 PM
Nov 18, 2015 01:34 PM
TfcCDR
Sep 14, 2015 12:08 PM
Sep 10, 2015 07:23 PM
uedlose
Sep 10, 2015 03:30 PM
