setting idle with automatic transmission without getting run over
Old Feb 10, 2009 | 08:28 AM
slick63's Avatar
slick63
Default setting idle with automatic transmission without getting run over
When you have an automatic transmission, to set the idle speed correctly, you must be in gear. However, the risks of putting the car in Drive (with the parking brake on of course!) and standing in front of it are obvious.
Here's a tip I figured out, perhaps it is already well-known to some of you, but here it is anyway:
1. Back the car up to a solid wall.
2. Put it in Reverse instead of Drive.
3. Set your idle without getting run over.
Old Feb 10, 2009 | 09:45 AM
kalli's Avatar
kalli
i never done this on my own, always had someone standing on brake inside. but if I hadn't that I'd just use a few good blocks of timber in front of wheels to avoid any scratching and denting
Old Feb 10, 2009 | 10:04 AM
Brian66's Avatar
Brian66
Not to hijack, but since you brought it up... what is the correct idle speed (in gear) for a 289/c4?
Old Feb 10, 2009 | 10:15 AM
Nick.Simonds's Avatar
Nick.Simonds
I seen a hilarious way to do it. My neighbor took a tow strap strapped it to a big tree, and the other end to his rear axle. Pretty comical to watch.
Old Feb 10, 2009 | 10:25 AM
rst08tierney's Avatar
rst08tierney
Are these all the things not to do? I think the tow strap to a big tree takes the cake.
It reminds me of an old comedy skit I once saw called "Red Neck Garage".
Old Feb 10, 2009 | 10:33 AM
Gun Jam's Avatar
Gun Jam
ya'll are way over complicating this
put the car in gear does it sound high or low?
If low put the car in park and adjust idle screw until you hear the engine rev just a bit put it back in gear does it still sound low? repeat if necessary. Same idea if its initially high.
-GUn
Old Feb 10, 2009 | 10:48 AM
69mach1377's Avatar
69mach1377
Exactly, and much safer.
Old Feb 10, 2009 | 10:57 AM
boogerschnot's Avatar
boogerschnot
I usually park the front tires against a curb and set the emergency brake.
Old Feb 10, 2009 | 11:27 AM
Starfury's Avatar
Starfury
-GUn
Exactly
Old Feb 10, 2009 | 11:34 AM
65rangoon's Avatar
65rangoon
-GUn
exactly what i did. exept i was doing this at my parents house so i had my dad sit in the car and put it in park/drive for me so i wasnt walking around constantly.
luckily though after tearing the carb down and rebuilding it the thing fired right up (MUCH better the before the cleaning/rebuild i might add). only thing i had to adjust was is would bog down when you would go to give it gas
