c4 filter change
Old Feb 10, 2009 | 02:49 PM
chappys4life's Avatar
chappys4life
Default c4 filter change
When doing a filter change on a c4 in a 66 mustang do I need to use silicone or anything on the pan or just the gasket the kit comes with?
I looked in the shop manual but didn't see any details about changing it. Oh what do I need to torque the bolts to as well.
Old Feb 11, 2009 | 10:36 AM
jc92073's Avatar
jc92073
Just the gasket, you don't need any other sealer.
Old Feb 11, 2009 | 01:16 PM
65rangoon's Avatar
65rangoon
you arent supposed to need silicone.
the filters now a days are better then the originals and will use the trans fluid to expand/seal better (basic explination)
Old Feb 11, 2009 | 05:16 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
silicone will make the fluid contaminated, install it dry
Old Feb 11, 2009 | 05:48 PM
groho's Avatar
groho
take two seconds and pick up a small drain plug from your local parts store and drill the pan, so you don't have to deal with the mess the next time you do this. you'll understand what I'm saying after you're done...
Old Feb 14, 2009 | 08:03 PM
st66ng's Avatar
st66ng
I just changed the filter and fluid in my 66 C4, I installed the the gasket dry and I torqued the filter to 40 Inch Lbs, and I torqued the pan to 12 Ft Lbs.
2007StangV6
Jan 28, 2016 06:09 PM
9550
Oct 26, 2015 05:01 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
Wombatnation
Sep 13, 2015 09:16 PM
