starting problems!!
Old Feb 15, 2009 | 02:41 PM
tazmo's Avatar
tazmo
Default starting problems!!
I have test everything, battery,starter solenoid, starter, stater cable, and all are good. I can cross the solenoid and the car will turn over but acts like it is not firing correctly. I checked the wires to the coil and when I took the red wire off the car started turning over continuiously with the key on. I cannot get the car to turn over with the key switch. What could be the problem?? Any help would be appreciated.
Old Feb 15, 2009 | 05:10 PM
kalli's Avatar
kalli
something in your wiring is messed up i'm quite sure.
are you saying you had key in ignition and when you remove the cable that goes to coil+ then the engine turns?
Old Feb 15, 2009 | 05:11 PM
kalli's Avatar
kalli
Old Feb 15, 2009 | 05:53 PM
tazmo's Avatar
tazmo
yeah, thats what happened. I took the hot wire off of the coil and the engine turned over
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
