when is a good time to install subframe connectors?
Old Feb 16, 2009 | 07:24 PM
restomod@16's Avatar
restomod@16
Default when is a good time to install subframe connectors?
I'm curious as to when a good time is to install a subframe connector. I dont have any frame damage or anything like that, but i'm looking to upgrade to lot more hp (approx 300hp from an I6 standard 100.... BARELY 100) in the near future and i'm sure i'll need to install some sort of bracing/support.
Old Feb 16, 2009 | 07:36 PM
69FB's Avatar
69FB
A good time is when there is nothing else that needs to be fixed on the undercarriage and you have the money.
Even if you do not go with a full 300hp the sub-frame connectors will make the body stiffer so it will handle better in the turns (less roll in the body). At least that's what I understand from what I've read and heard.
Old Feb 16, 2009 | 08:18 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Any time is a good time
Old Feb 16, 2009 | 08:22 PM
LCC's Avatar
LCC
NOW....
Old Feb 16, 2009 | 08:36 PM
andrewmp6's Avatar
andrewmp6
Go for it they stiff the car up a lot makes it ride better and handle better.
Old Feb 16, 2009 | 08:42 PM
pascal's Avatar
pascal
If it wasn't for them, my car would have been totaled...
It saved the back end.
The rear axle got shoved under the trunk and flattened the frame rail, smashed the gas tank.
It buckled the other quarter but held good.
Those aren't good pic of that ordeal since I'm working on the car right now.
I have some close ones right after the wreck and you can see that the sub frame connectors held the back end good.
Just can't find them right now...
I have the tubular Global West that connect (welded) past the torq boxes towards the back on the rail.
Thanks for that
Old Feb 16, 2009 | 09:11 PM
jspagna1's Avatar
jspagna1
Originally Posted by LCC
NOW....
Totally agree +1
Old Feb 16, 2009 | 09:49 PM
valley firearms's Avatar
valley firearms
I wish I had installed mine before the body started twisting and cracking. I have them now and I'm sure they will come in handy. I won't know how they ride until spring
djbigskrilla
Sep 20, 2022 01:04 AM
Diode Dynamics
28
May 26, 2022 12:02 PM
MXBT187
Aug 20, 2015 02:36 AM
Stilz
Aug 19, 2015 06:17 AM
WDScott
Aug 17, 2015 06:38 AM
