Air Filter Dimensions
Old Feb 26, 2009 | 02:55 AM
tx65coupe's Avatar
tx65coupe
Arrow Air Filter Dimensions
I need to get an air filter element for my 65.
Its going to have a 302 with Edelbrock performer rpm intake and Edelbrock 650 AVS carburator.
I want to get a KN X-Stream top filter. What size should I go with?
I have seen that the HiPo 289 filter is a 14 x 2 1/4 element.
Can I run a drop base and a 3 inch filter?
What size is the tallest you can go and have hood clearance?
How much drop can the base have if any?
Old Feb 26, 2009 | 03:00 AM
kalli's Avatar
kalli
if you drop you get it under the hood but the air is sucked up and then voilently down. This is not a recipe for performance. The open top is KN X-Stream top filter as it can suck air straight down. from this I wouldn't drop a bit if you don't have to. if the intake and carb are the only power adders then the 14x2 1/2 with that top is more than plenty I'd say
Old Feb 26, 2009 | 03:22 AM
tx65coupe's Avatar
tx65coupe
I wasn't sure. I thought the drop base might be bad idea. I just wanted to see what others opinions are.
KN suggested using a drop base if it would work. Does it really mess up airflow?
It will also have Edelbrock aluminum heads and a fairly aggressive cam. I forget the specs at the moment.
KN doesn't have a 14 x 2.25 element. They have a 14 x 2.31 element. I assume that I can run that one since it isn't much taller. I figured that with the Xstream top it should allow enough air to get in. Can I go with a 2.5 inch tall element. I thought that it might be to close to the hood.
Old Feb 26, 2009 | 06:36 AM
jspagna1's Avatar
jspagna1
This is what I have on my car. The base is actually the Hi-po Blue base with a K&N 14" x 2 3/4"? (not sure exactly) with X-Stream top. But I have a GT350 fiberglass hood. I pretty sure you will have to go with a drop base. Then you'll be good to go. Here's what mine looks like:
http://www.putfile.com/pic/4991979
jwog666
Dec 27, 2021 08:09 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
svfetter
Oct 5, 2015 11:39 AM
Sixer4Life
Sep 28, 2015 07:05 AM
uedlose
Sep 10, 2015 01:37 PM
