AOD TV cable adjustment
Old Mar 4, 2009 | 05:57 PM
65Rocky's Avatar
65Rocky
Default AOD TV cable adjustment
How do you adjust the TV cable??
Have a AOD in a 65 with Eddy carb.
Old Mar 4, 2009 | 06:43 PM
dano670's Avatar
dano670
I have the 4100. I didn't use the tool to measure mine, but trial and error. No tension on the cable ruins the transmission. Too much makes the throttle too touchy and the car downshift too easily. So I put too much tension on the cable then backed it off until I was happy.
But this is not the right way but better than leaving the cable slack.
Old Mar 4, 2009 | 08:08 PM
fakesnakes's Avatar
fakesnakes
That's actually not a bad method. The best is to measure pressure, but that is a bit of a pain and you need the right tool.
Old Mar 4, 2009 | 08:36 PM
65Rocky's Avatar
65Rocky
Right now it shifts to early. when I stop, it is slow to down shift
btw- I still have the 280 gear in the 8inch
Old Mar 5, 2009 | 03:42 AM
gcroix's Avatar
gcroix
I set mine from a youtube video, put out by a transmission tech, worked great first time. You say you have a 2.8 gear in your differential? Wow..how fast does she go?
Old Mar 5, 2009 | 07:55 AM
urban_cowboy's Avatar
urban_cowboy
Here is a how to that may help.
http://www.txchange.com/aodadj.htm
Here is a youtube video
http://www.youtube.com/watch?v=6L3hNzxdiYw
I need to adjust mine on the Bronco. It will hardly downshift.
Old Mar 6, 2009 | 08:15 AM
urban_cowboy
FYI, I adjusted the TV cable on my 88 Bronco AOD last night. Since the tranny was installed, it would not downshift unless I REALLY mash the pedal. I moved it about two teeth or a 1/16" so that I had to just stretch the cable just a little to hook it up. I then went for a test drive and it shifted MUCH better. Do not be scare of tweaking this cable, but it sounds like it is better to be slightly too tight (quicker downshift) that slightly too loose and have it trash the tranny.
Old Mar 6, 2009 | 09:43 AM
fakesnakes's Avatar
fakesnakes
You are correct, sir!
Old Mar 7, 2009 | 10:30 PM
65Rocky's Avatar
65Rocky
thanks it is better now,tighten it down a little. helped a lot..will try more when I get some leave again.
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
winner99
Sep 30, 2015 07:04 PM
