Not starting
Old Mar 8, 2009 | 05:19 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default Not starting
Trying to prep the mustang before it goes up for sale. We can't get it to crank now. Might have killed another battery, this one is only around 2-3 months old. We tried to jump it with my dads truck and put it on a battery charger and it doesn't even get a full crank before going dead. What is wrong?
I still have to replace my voltage regulator, but it cranked fine yesterday.
Old Mar 8, 2009 | 06:11 PM
Starfury's Avatar
Starfury
A bad voltage regulator can drain a battery in very short order.
Old Mar 8, 2009 | 06:21 PM
1slow67's Avatar
1slow67
ROTM Moderator
I'm buying one tomorrow. It was over charging the battery and now it is draining it. Going to get the battery checked while I am at it.
Old Mar 8, 2009 | 07:29 PM
1965fastback's Avatar
1965fastback
I say replace the VR and then keep it. A bad voltage regulator might have been killing coils.
Old Mar 8, 2009 | 07:48 PM
1slow67's Avatar
1slow67
ROTM Moderator
Keeping it isn't an option for me. I can't trust the mustang anymore. I'm fixing it and then selling it.
Old Mar 8, 2009 | 08:52 PM
Gun Jam's Avatar
Gun Jam
I don't normally recommend this but I think you should stick with you gut feeling on this one BA and sell it. There is plenty of time down the road to pick up another one. With your school situation and all I think you're making the right choice.
-Gun
Old Mar 8, 2009 | 09:24 PM
1slow67's Avatar
1slow67
ROTM Moderator
I plan on getting another after college. Maybe get lucky and buy this one back from the person I sell it to if they still have it in about 4 years.
Old Mar 8, 2009 | 10:14 PM
1965fastback
If it is paid off then store it and go back to it later. You will probably regret it later when you see the guy you sold it cruising around in it. To fix the voltage regulator you could get a GM alternator that has a voltage regulator built into it. That alt. only needs slight mods to the body to fit right.
Old Mar 8, 2009 | 10:19 PM
1slow67's Avatar
1slow67
ROTM Moderator
I paid cash for it, so it is completely paid. We have no where to store it. It would sit in the driveway.
Replaced the alternator back in November.
Old Mar 9, 2009 | 01:50 AM
66mustang302's Avatar
66mustang302
Batteries usually fail right around their rated lifespan, like the others said I would check the voltage regulator and work from there.
Electrical issues are a pain to figure out, but it helps if you take the wiring diagram and look at it logically, start from the battery and work your way from there till you figure out where the problem is
