need help with 65 mustang problems
Old Mar 9, 2009 | 08:22 PM
ryan8889's Avatar
ryan8889
Default need help with 65 mustang problems
i have a 65 mustang coupe 289 and i haave been having trouble with it. the problem is my battery is not staying charged but its not the battery or the alternator had it checked so i replaced the voltage regulator and the solenoid because i thought that could be the problem but it still is not charging if anyone has any idea of what i could be let me know thanks
Old Mar 9, 2009 | 08:47 PM
racin66coupe's Avatar
racin66coupe
maybe a bad ground? or a short somewhere? check all the wiring that the battery connects to.
im not really sure just an educated guess
Old Mar 9, 2009 | 08:54 PM
rst08tierney's Avatar
rst08tierney
4 things.
How new is your battery?
Whats is the Cold Crank Amp amount?
How was the battery and alt checked?
Check your grounds!
Old Mar 9, 2009 | 09:10 PM
Tony R's Avatar
Tony R
did you clean your terminals?
Old Mar 9, 2009 | 09:11 PM
ryan8889's Avatar
ryan8889
the battery is 3 days old and has 600 cold crank and the alt was checked by auto zone
Old Mar 9, 2009 | 09:12 PM
ryan8889's Avatar
ryan8889
yea the battery and terminals are all new just bought 3 days ago
Old Mar 9, 2009 | 11:10 PM
pootypeters's Avatar
pootypeters
Check the wiring harness that plugs into the side of your voltage regulator. You might have to use a screw driver to close the gaps on the connections so that it makes a more solid electrical connection. This simple problem caused me a week of heart ache which also cost an unnecessary $200
FD725
Aug 23, 2015 06:43 AM
jjwinel78
Aug 17, 2015 03:34 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
daytooday
Aug 11, 2015 09:22 AM
philster0306
Aug 10, 2015 11:33 AM
