Bent Flex Plate Woes
Old Mar 9, 2009 | 09:40 PM
Carlos Pineiro's Avatar
Carlos Pineiro
Default Bent Flex Plate Woes
Freaky. The pinion gear from my starter broke in two and the pieces spun around and bent my flex plate. It sounded like someone threw rocks in a blender. Nasty. The plate now taps against the bell housing. The motor runs fine (new starter) but it sounds like TINGTINGTINGTINGTINGTINGTINGTINGTING.
Tell me if this makes sense: I think I can do this up on jack stands and just slide the supported tranny back a bit after dropping the driveshaft, then spinning the flex plate so that the bolts are at the bottom so I can access them.
1. Will this work?
2. Is there a proper bolt tightening pattern and how much torque?
The local garage wants $300 labor to do this. Too much.
Any thoughts? Thanks.
CP
Old Mar 9, 2009 | 09:43 PM
Joe67's Avatar
Joe67
Banned
only one way to find out i guess....
worst comes to wort you just pull the tranny completely, which is tooo hateful, compared to 300
Old Mar 9, 2009 | 10:03 PM
Tony R's Avatar
Tony R
I think you are going to be removing the tranny all the way. Just pulling it out a little is a lot to hope for.
Old Mar 9, 2009 | 11:51 PM
4reboy's Avatar
4reboy
yeah I think you would have to pull it out since the flywheel bolts are more near the center...
remove the access panel to the bell housing and be sure remove the bolts connecting the flywheel to the torque converter, then remove the tranny and replace the flywheel. I'm sure a bent one can't be good for the balance of the engine...
Old Mar 10, 2009 | 01:34 AM
Carlos Pineiro
Thanks, guys. I am keeping the rpms low (no freeway) until I replace the plate.
CP
Old Mar 10, 2009 | 06:33 AM
Stepman's Avatar
Stepman
I would jack it up and spin it by hand to seeif you can tell where it's hitting. You may just still have a small piece of gear in there. It could also have bent the stiffener plate where the starter goes in. I'm just thinking out loud but, if the flexplate bent, it should have more of a constant rub to it.
Old Mar 10, 2009 | 03:15 PM
jlg2002's Avatar
jlg2002
1. Will this work?
CP
Carlos, its been my experience that's it's easier to drop the tranny then trying to work around it. as far as the crank bolts are concerned the FSM shows 75-85 Ft lbs . always do circular bolt patters in a star ( like a tire and rim) go up in torque 1/3rds.
JLG
Old Mar 12, 2009 | 02:57 AM
Carlos Pineiro
JLG
Thanks.
I might as well drop the tranny so I can adjust my neutral safety switch as well as tighten up the shifter linkage.
CP
Old Mar 12, 2009 | 03:05 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
just make sure to spray some liquid wrench on the tranny lines and let it sit for a while
mtgldr
Feb 3, 2024 09:00 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
mdg
Oct 1, 2015 07:04 AM
winner99
Sep 30, 2015 07:04 PM
