Battery Won't Charge?
Old Mar 10, 2009 | 11:16 PM
knuckless's Avatar
knuckless
hahaha well all those things have been checked. yeah i was a little skeptical on the alternator working properly, i almost just bought a new one for the heck of it. well see im going to check more tmrw and see what happens. The solenoid has nothing to do with this right? I mean i got a new one sitting around and I was going to swap that out since I had it.
Old Mar 11, 2009 | 12:38 AM
rst08tierney's Avatar
rst08tierney
Originally Posted by knuckless
the alternator is fine, i was hoping that was the problem, easy $35 fix. i got like 4 battery jumpers so I'll make it to the autoparts store. what do they have to test my car with? i mean will it cost anything? they already tested my alternator when I brought it in monday.
How do you know the alternator is fine? You tested it how?
What is the Cold Crank Amp rating of your batt?
Old Mar 11, 2009 | 08:04 AM
musnicki's Avatar
musnicki
Alternator is good? Battery is good? Lead from the alt is good? Well then you have not ruled out the belt?
It sounds like it’s either loose or could be dry rotted and not turning the pulley on the alternator. Some times when they get old they can dry rot out, just grab the belt (when the car is off) and squeeze it, if rubber flakes off onto your hand or turns your hand black then it’s probably time to get another belt.
If the belt is loose….you take a straight edge from the alt pulley to the water pump pully, then take a ruler and push down in the middle of the distance on the belt from the alt to the water pump. I think the general rule is no more than an 1” of play on the belt.
I hope that helps.
From Iraq:
James
Old Mar 11, 2009 | 08:57 AM
pinboy122's Avatar
pinboy122
sounds like you have something hooked up wrong.I drive my 65 around for days with no alternator and a high energy ignition system,it takes quite a while to drain the battery to the point where it wont start, let alone drain it to the point where the lights dont work.I would go through and check every connection starting at the battery.If the alternator is working you should have at least 14v at the battery.
Old Mar 11, 2009 | 11:13 PM
knuckless's Avatar
knuckless
ok i finally figured it out, just to let you know here is the list of things replaced
battery $75
new fan belt $13
voltage regulator $55
alternator $55 (never installed it but finally gave in and bought it because i couldn't figure out what else could be wrong)
$198 spent all for nothing (except i need the fan belt)
i tested the grounds coming from my voltage regulator and neither one was grounded correctly. so i grounded the ground wires and jumped my car, turn the lights on and it ran without shutting off. so the voltage problem was fixed. then i tried starting the car but no power, so i tested to see if the battery cables were getting enough volts. turns on they were only getting 3 volts because the inside part of the connection to the battery were completely corroded over. cleaned them and every works fine now. stupiddddddddd
the only reason the car was starting was because the jumper cables were connecting to the outside part of the wires that weren't corroded.
thanks for the help guys
Old Mar 12, 2009 | 01:33 AM
Starfury's Avatar
Starfury
Aha. Well, glad you figured it out. Look at it this way, though: now you've got a bunch of new parts you don't have to worry about replacing for a while
Old Mar 12, 2009 | 07:51 PM
az1966's Avatar
az1966
pretty much as stated above check connections,,loose,,dirty etc,,,,to see if it's the battery just start the car somehow and pull the neg off the battery and jumper cables,,if the car dies issue is somewhere else
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
ChampInSD
Oct 2, 2015 04:55 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
