Which Comp Cam?
Old Mar 11, 2009 | 06:21 PM
jim1967's Avatar
jim1967
Default Which Comp Cam?
I am about to re-build my 289 2 barrel with a 4 barrel and have narrowed the cam down to the comp cam xe262h or xe268h and am trying to get some feed back on the performance. I have a c4 and will change my converter to a 2000 stall and have a 3.4 posi rear end. i am not sure what the current compression is but feel it is stock as the engine was re-built to .030.
Old Mar 11, 2009 | 06:40 PM
Starfury's Avatar
Starfury
Which heads/intake are you running? Are you planning on changing the valve springs as well? Also, how do you drive the car? Is it a daily driver or a weekend car? Does it see time at the strip? Do you have headers?
Old Mar 11, 2009 | 06:45 PM
my77stang's Avatar
my77stang
I'd be looking at a lunati voodoo #61002 or 61003. Also, if your going to go with a high stall get something that's at least 2400 or 2500.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
junior04
Sep 28, 2015 10:53 AM
