5 speed tranny conversion
Old Mar 16, 2009 | 11:48 PM
remicks's Avatar
remicks
Originally Posted by JamesW
Shade tree method:
Buy a used T5 off Craigslist. You should be able to get the trans, bellhousing and yoke for 500 or so.
Get used flywheel off 90 Mustang GT for a few bucks and have it rebalanced to 28oz. Cost about 75 bucks
Invest in a FMS King Cobra Clutch/Pressure plate setup. Cost about 200 bucks
Will require to have the driveshaft length cut down. Cost about 200 bucks
Install MustangSteve Cable clutch or do homemade hydraulic clutch. Cost roughtly 200 bucks.
If you still have money.... get a Pro50 aftermarket shifter. Use cost 100-150 bucks.
So, plan on 1300-1400 bucks AT LEAST
James is about right. I'm in the middle of my swap, I just need time to put the parts in right now. But the costs as it stands.
T5/Yoke/Bellhousing - $300
Clutch (Came with a new clutch/pressure plate so I got lucky) - Free
28oz Adapter Flywheel - $99 from www.themustangdepot.com P/N HR-FW-1600
Mustang Steve's Cable Clutch kit - $219
T5 Tubular Crossmember - $139
Reenmachine Shifter - $99 http://www.reenmachine.com/shop/prod...cat=253&page=1
Driveshaft - Waiting for install to see how much to cut
So with a couple freebies and being lucky I'm up to $915 and probably around $1000 after the driveshaft and I'm sure another odd or end and beer.
Old Mar 17, 2009 | 09:24 AM
whitestang07's Avatar
whitestang07
is it cheaper to keep in the 3 speed
Old Mar 19, 2009 | 03:20 AM
remicks's Avatar
remicks
I would imagine it would be cheaper to just rebuild the 3 speed. For an OEM style clutch kit you are looking at around $150 to $200 or aftermarket $200 to $400. And then $100 to $150 for the transmission rebuild kit.
Old Mar 19, 2009 | 06:22 AM
JamesW's Avatar
JamesW
yeah, you got out cheap on the transmission. I paid over 200 to have the driveshaft 'reshafted'. And the Cobra Clutch is 200 or so
Old Mar 19, 2009 | 08:15 AM
remicks's Avatar
remicks
I did get lucky, the guy I bought it from just bought a fox for the motor and just wanted the trans gone. I just happened to be the first to respond luckily. Plus when he pulled it it happened to have a virtually brand new clutch. Then he gave me the driveshaft, yoke, block plate and starter because he had no use for them and wanted them out of his garage. So I guess lucky works
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
BeatnikFink
Oct 1, 2015 08:00 PM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
