LCA Removal Help
Old Apr 1, 2009 | 09:27 PM
90RunnerRed's Avatar
90RunnerRed
Originally Posted by Starfury
I still hate pickle forks. The 'proper' way to do it is with a puller, and the next best way is the double-BFH method. That way you don't damage anything if you need to put it back together. It usually only takes a couple whacks anyway.
As far as the cross brace goes, I've never had problems with my car shifting while the cross brace was out. Obviously you shouldn't drive it like that, but go ahead and take it out, then pop it back in if you're afraid you won't be able to get it back in later.
How much do the pullers usually run? Not that I plan on doing this too often, but I always like having the "right" tools.
Thanks for the advice on the cross brace, I just wanted to make sure.
Old Apr 1, 2009 | 09:29 PM
90RunnerRed
Originally Posted by sschanz
I had the same issue. I am telling you, get a 5lb hammer and give it 3-4 GOOD SOLID blows and it'll pop right out. You gotta smack it and it will drop with the force behind it. Over and done!
Where did you get a 5lb? All I could find is 4lb. It seemed to jump from 4lb to the big 8lb, full sledge hammers. Not that I'm complaining, it worked.
Old Apr 1, 2009 | 11:04 PM
Starfury's Avatar
Starfury
An individual ball joint separator will run $40-100, depending on how nice it is and where you get it from. Ideally you get a full suspension puller/separator shop set, but that'll set you back several hundred, if not over $1k.
Old Apr 1, 2009 | 11:36 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
heres an article for anyone else wanting to read about this method
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
UrS4
Sep 30, 2015 10:13 AM
