LED lights flasher replacement
Old Mar 22, 2009 | 12:05 PM
paddy187's Avatar
paddy187
Default LED lights flasher replacement
So I brought my LED rear lights not knowing I would need to change the flasher unit. So i got the flasher module from mustang project but it came with no instructions and no luck by contacting them by mail. So does any body have the instructions that they could skan for me? Also were is the flasher module on a 65 and what does it look like?
Cheers
Old Mar 22, 2009 | 01:55 PM
ThanksDad's Avatar
ThanksDad
Mine (for a 66) was a direct plug in replacement. The old one was behind the dash by the glovebox. It was a round plastic piece about 3/4" - 1"tall. I went out to the garage to snap a picture but I can't find it. I assume a 65 would be the same.
Old Mar 22, 2009 | 02:04 PM
MIL1ION's Avatar
MIL1ION
Turn the turn signals on to locate the existing flasher ..shut them off and insert the new flasher
Old Mar 22, 2009 | 03:05 PM
paddy187's Avatar
paddy187
Thank thanksdad I was looking on the wrong side by the looks of things.
Old Mar 22, 2009 | 06:39 PM
kaiser18's Avatar
kaiser18
If your flasher is the old ticking canister you can turn on your blinker listen around. On mine I found it behind and slightly below my radio. Bit of a bitch to reach. Just a note, I don't know about your LED kit but mine didn't require the new flasher to be in place. It was a trade off. The new flasher supports the tail light blinking patterns but has no actual *ticking* sound. While my old flasher did make the *ticking* sound but didn't support the facny turning left or right patterns, only blinking. I had a choice and went with the new flasher.
Old Mar 23, 2009 | 02:12 AM
paddy187's Avatar
paddy187
Unfortunatly with the LED lights in place i don't get the tick. I was told by the chilton's manual it is behind the instrument panel near the steering column. But it wasn't I will check out some time this week.
Old Mar 23, 2009 | 10:32 AM
boogerschnot's Avatar
boogerschnot
They usually sit in a clip behind the radio..
Old Mar 23, 2009 | 10:51 AM
mushaus's Avatar
mushaus
On my 66, the flasher for the turn signal was attached to a clip on the drivers side fresh air vent. So the description "it is behind the instrument panel near the steering column" would be about right for mine.
The flasher unit under the dash by my glove box is for my emergency flashers.
Old Mar 23, 2009 | 11:01 AM
Nick.Simonds's Avatar
Nick.Simonds
That is where mine is at, on the firewall next to the column. Seems to be that they can be anywhere. Just poke around and see what you can find.
djbigskrilla
Sep 20, 2022 01:04 AM
Diode Dynamics
28
May 26, 2022 12:02 PM
bond007
Aug 26, 2015 11:36 PM
kdryan
Aug 21, 2015 04:01 PM
inyadreems
Aug 21, 2015 09:10 AM
