Changing gears?
Old Mar 25, 2009 | 07:04 PM
kalli's Avatar
kalli
if you have those tyres and are doing 70mph you should have the following rpms (this assumes you have 2.79:1)
2638 in 4th gear
1794 in 5th gear (t5)
if you change that to a 3.5:1
you'll have
3310 in 4th and
2251 in 5th (which is still good)
at 70mph
if I'd take the max speed you could do in the gears at 5000 rpm
with 2.79 gearing:
40 in 1st
67 in 2nd
100 ..
133
195 in 5th (that's all theoretical if you had enough HP)
with 3.5 gearing this will change to:
32 in first
53 in 2nd ..
80 3rd ...
106 4th
156 th
i got this info from a calculator i made myself when I had to decide for new gearing.
So basically if the following is valid: "you can do 70mph in 5th at 1800 rpm", then the following will be valid as well:"2250 rpm in 5th at 70mph"
and all the rest ...
Old Mar 25, 2009 | 10:31 PM
cprstreetmachines's Avatar
cprstreetmachines
If everything was installed correctly, the hesitation just sounds like a lean spot in the pump shot. Pretty common when adding HP.
Old Mar 26, 2009 | 12:46 PM
_Remi's Avatar
_Remi
Thanks for all this information, I will check my RPM next time on the freeway.
I posted an update here: https://mustangforums.com/forum/clas...ml#post6060312
Luke9222
Oct 22, 2015 11:55 PM
musnicki
Sep 23, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 3, 2015 07:14 PM
