Horsepower
Old Jun 16, 2005 | 07:25 PM
6mustang6's Avatar
6mustang6
Default Horsepower
Ok, When you look in the 1966 Mustang Shop manual it says the 289 with 2v has 200 bhp. Doesn't bhp mean hp at the wheels. I know they dont have that much HP, so how much is a stock 289 2v getting at the wheels with a C4 with stock rear end. I believe my gears are around 2.80.1
Old Jun 16, 2005 | 07:36 PM
stangrr66's Avatar
stangrr66
Default RE: Horsepower
I think I found what youre looking for, it says right here that its about 140 to the wheels. But i dont know how reliable this site is.
Old Jun 16, 2005 | 08:39 PM
66FordStang's Avatar
66FordStang
bhp means braked horse power and this is the defination i found.----The measure of an engine's horsepower without the loss in power caused by the gearbox, generator, differential, water pump and other auxiliaries. The actual horsepower delivered to the driving wheels is less.
Old Jun 16, 2005 | 08:43 PM
73Cleveland's Avatar
73Cleveland
Wasnt the way HP was listed changed in the early 70's from NHP (net HP) to BHP (brake hp)? So the nbrs you see could be the old NHP? There was quite a difference between the 2.
I could be wrong about this but I think they did change around 70-73 or so.
Old Jun 16, 2005 | 08:45 PM
73Cleveland
Maybe I got my terms backwards!
Old Jun 16, 2005 | 09:04 PM
73Cleveland
This cleared it up for me. Takes it a bit more time for me to let things sink in!
Torque is power is force x distance (ft-lb). It's what turns the crankshaft.
Horsepower is work is torque x time (torque x rpm ÷ 5252).
Brake horsepower is measured on an engine dyno and is taken at the flywheel or transmission output shaft (depending upon standard). Originally, dyno used a water brake to apply resistance against which the engined worked. SAE Gross HP was measured on engine in which ALL accessories were driven by external power source, even the water pump, and engine was hand-fitted to provide largest capacity using off-the-shelf components (blue-printing). This standard provided a rather theoretical figure and was used until about 1970. SAE Net HP required actual production engine with all accessories and transmission attached. This gave a much more realistic horsepower figure the car buyer could actually expect as it takes into account the power needed to spin the accessories. Still taken on an engine stand though dyno is now typically an eddy-current dyno, though water brakes are still in use.
Wheel horsepower is measured at the wheel, naturally, on a chassis dyno. This accounts for driveline losses that SAE Net test doesn't see.
Old Jun 17, 2005 | 05:00 AM
Soaring's Avatar
Soaring
I ♥ Acer
What really matters though, is what HP you have at the rear wheels.
Old Jun 17, 2005 | 09:59 AM
73Cleveland
Very true! The only problem is that a lot of sources (Mfg's, builders, speed shops) that list HP don't always use the same designations.
Old Jun 17, 2005 | 10:07 AM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, usually they only list the highest number they can get away with without lying about it which would be the dyno with an outside source for running the water pump, etc.
Old Jun 17, 2005 | 10:11 AM
1970 mach1's Avatar
1970 mach1
A good Dyno test will tell you the true Hp to the wheels.
