Please help with Ignition system problem
Old Mar 26, 2009 | 03:16 PM
ddytchko's Avatar
ddytchko
Angry Please help with Ignition system problem
ok, so i have a new MSD 6al ignition system, new msd ignition coil, new voltage regulator, and a new battery and distributor. My problem is that when i turn the key, the engine turns over but wont start. there just isnt any spark to the coil. why is that? what can i do?
Old Mar 26, 2009 | 03:18 PM
Nick.Simonds's Avatar
Nick.Simonds
Seems to be a LOT of questions about those boxes lately...
Someone with knowledge of them will be by soon.
Old Mar 26, 2009 | 03:26 PM
Starfury's Avatar
Starfury
First thing that comes to mind, are you supplying the system with a full 12V? The factory wiring to the coil includes a resistor wire from the back of the ignition switch out to the firewall connector. This cuts the voltage to the coil to about 8V to keep from burning out points. Many aftermarket ignitions require a full 12V to function properly, which requires that you bypass the stock ignition resistor wire.
Old Mar 26, 2009 | 04:03 PM
EZFEED's Avatar
EZFEED
Did you ensure the ground was good?
Old Mar 26, 2009 | 04:30 PM
ddytchko's Avatar
ddytchko
yes, ive checked all the grounds and there is a current going through all the wires yet still no spark, on my last ignition system i didnt use the points wire at all and it worked but no there still is no spark.
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
zanemoseley
Sep 6, 2015 12:58 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
