Needing duraspark help on 67 mustang
Old Apr 16, 2009 | 02:08 PM
jayzee2627's Avatar
jayzee2627
Default Needing duraspark help on 67 mustang
i need help with the white wire and the two red wires on the duraspark.
i don't know where they go and so far no diagram i have tried has worked.
i will be greatful for any help on this, thank you.
Old Apr 16, 2009 | 02:48 PM
jc92073's Avatar
jc92073
try this link
http://www.mustangsteve.com/conversion.html
Old Apr 16, 2009 | 03:46 PM
jayzee2627's Avatar
jayzee2627
i have tried it and still nothing.
any ideas?
Old Apr 16, 2009 | 04:06 PM
1slow67's Avatar
1slow67
ROTM Moderator
I did this swap, i'll have to look once my dad gets back with the coupe. Is your engine a I6 or V8?
Have a picture of the ignitor module?
Old Apr 16, 2009 | 06:46 PM
jayzee2627's Avatar
jayzee2627
its a V8
sorry i don't have and pictures
Old Apr 16, 2009 | 07:32 PM
1slow67's Avatar
1slow67
ROTM Moderator
Is it a blue connector module?
Old Apr 17, 2009 | 12:13 PM
jayzee2627's Avatar
jayzee2627
yes it is
Old Apr 19, 2009 | 09:54 AM
stefke's Avatar
stefke
I think i can help you out, i have put in an duraspark in an '71 grande with 302.
This duraspark cae out of an '79 Bronco. First some pics:
There are 2 connectors coming out of the Motocraft box.
From the 4 wire plug:
*the green wire goes to the neg. of the coil.
*the orange, purple and black wire go to the distributor.
From the 2 wire plug:
*the red wire goes to the starter relay, "I" port.
*the white wire goes to the coil +.
Note: If i recall correct, the duraspark needs 12v on the coil. In the '67 could be an resistor wire on the coil + that restricks it to about 9v. you should look in to that.
Good luck,
SANDY21
Aug 17, 2015 02:41 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
defarmer
Aug 13, 2015 06:40 AM
daytooday
Aug 11, 2015 09:22 AM
