Vacuum line
Old Apr 25, 2009 | 06:28 AM
kalli's Avatar
kalli
yah. that line is no fuel. use rubber. will do fine if you don't have a steel line
Old Apr 25, 2009 | 02:28 PM
MIL1ION's Avatar
MIL1ION
Yes Steel for fuel line....rubber hose (vacuum type hose) for vacuum lines
Would you like me to go take a close up photo of my ORIGINAL set up?
Old Apr 26, 2009 | 12:53 AM
JMD's Avatar
JMD
Originally Posted by 109jb
It is possible that your distributor is aftermarket and is only mechanical advance and doesn't have a vacuum advance. If your distributor doesn't have something like the item circled in red in the picture below then you have a mechanical advance only distributor.
And that IS NOT a bad thing IMO...
NEVER MIND...
Should have read one more post before answering...
Old Apr 26, 2009 | 05:48 PM
classicman's Avatar
classicman
Ok I went out and bought a new diaphragm assembly as well as the rubber hose. I hooked it up according to the pictures and all seems ok. Now what is the best way to adjust my timing. I have been reading online and this is what I am guessing:
Take off vaccum line and set for 6 degrees at idol.
Then with vaccum line back on set to 36 degrees. I read you can adjust vaccum on the new diaphragm with an allen key. Now the second adjustment must be made at the diaphragm correct?
Any thing I am missing before attempting. Once again I have never done this before. I am borrowing a timing light off a guy.
Old Apr 28, 2009 | 09:48 AM
kalli's Avatar
kalli
nah.
disconnect the vacuum advance at distributor side and block the hose (so carb can't pull air through there). 8 degrees in idle.
then with vacuum advance still disconnected slowly rev the engine and the timing should further advance. 34 degrees at 3000 maxxing out is about good. if there's any difference that can be corrected with different springs or stoppers on the centrifugal weights.
plug the vacuum advance back in and drive. I don't have data to adjust the vacuum advance. its guesswork and trial and error
if you hook up the vacuum to the manifold port of distributor (instead of ported) you will need to re-set the carburator (curb idle and mixture screws) as idle will increase with the thing plugged in.
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
