Harmonic Balancer Replacement
Old Apr 26, 2009 | 06:05 PM
UBY289's Avatar
UBY289
Default Harmonic Balancer Replacement
I am replacing the Harmonic Balancer on my 67 ,289. Is the bolt that holds it on a standard thread or a lefthanded thread . I will use a puller to get it off. Any suggestion on how to loosen this bolt other than kranking on it. What would be the troque of this and the three bolts that hold the pulley on. Thanks
Old Apr 26, 2009 | 07:50 PM
trashline's Avatar
trashline
to remove i just gave it a quick shock with an impact gun and it came off.
did you get may 2009s mustang monthly? they give you some good tips on installing a balancer.
Tq specs say 70-90 ft/lbs
http://www.treasurecoastmustangs.com/bolttorque.htm
Old Apr 26, 2009 | 08:24 PM
UBY289's Avatar
UBY289
Yes I did , Thanks
Old Apr 26, 2009 | 09:54 PM
JMD's Avatar
JMD
standard rotation on the threasds.
Old Apr 27, 2009 | 11:11 AM
amfstang's Avatar
amfstang
to loosen the balancer bolt you can always pull the coil wire take a long pull bar position it over the frame rail have a buddy bump the starter works every time no impact needed just watch your fingers
Old Apr 27, 2009 | 12:31 PM
trashline's Avatar
trashline
F that lol. Im a crazy person when it comes to some things but I wouldnt try that lol.
Old Apr 27, 2009 | 12:36 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
im not a crazy peson and i do it all the time just use a breaker bar and the starter does all the work for you
Old Apr 27, 2009 | 05:19 PM
UBY289's Avatar
UBY289
I used my cordless impact drill and the bolt came loose . Than I just gave the harmonic a little pull and it came right off didn't have to use a puller at all. LUCKY Me!!! Thank for all the tips.
mtgldr
Feb 3, 2024 09:00 PM
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
MusicCity615
Sep 12, 2015 07:05 AM
Sep 8, 2015 11:50 AM
