Instrument Cluster Voltage Regulator
Old Apr 29, 2009 | 01:59 PM
tx65coupe's Avatar
tx65coupe
Question Instrument Cluster Voltage Regulator
Does anyone know how the instrument cluster / panel voltage regulator works? Mustangs Unlimited also says it is referred to as the "constant voltage regulator" Is it really a regulator or more of a resistor?
This is the part I am talking about.
http://www.mustangsunlimited.com/ite...sp?T1=GR508+01
I have another thread about my issue with gauges here.
https://mustangforums.com/forum/clas...new-302-a.html
Old Apr 29, 2009 | 02:48 PM
jc92073's Avatar
jc92073
This link talks about how it works
http://www.mustangandfords.com/techa...ity/index.html
Old Apr 29, 2009 | 03:30 PM
tx65coupe's Avatar
tx65coupe
Thanks for the link.
I am going to go over it later tonight.
Old Apr 29, 2009 | 09:37 PM
The Ultimate Ford Info Guy's Avatar
12 volts is supplied to one side of the ICVR causing a steady 5 volt pulse of power through the signal wire to the applicable sending units.
Here is an example of the Fuel indicating system
It is the silver box part located just under the speedo head connection shown here.
Old Apr 29, 2009 | 10:19 PM
JamesW's Avatar
JamesW
Old Apr 29, 2009 | 10:34 PM
ThanksDad's Avatar
ThanksDad
You didn't ask but I am going to recommend if you buy a new one spend the extra money for an electronic unit. I went through three of the old style before I spend the $50 or so on a electronic unit. It has been working great.
Old Apr 30, 2009 | 10:38 AM
tx65coupe's Avatar
tx65coupe
I have a new one installed right now.
Where do I get an electronic one?
Of all the ones we have had, our original one was the only one that seemed to work right.
Old Apr 30, 2009 | 10:41 AM
tx65coupe's Avatar
tx65coupe
Ultimate Ford Info Guy,
Whats the first picture of?
Thats interesting to know that is sends a pulse.
Old Apr 30, 2009 | 10:44 AM
tx65coupe's Avatar
tx65coupe
Thanks for the diagram James.
Old Apr 30, 2009 | 11:01 AM
109jb's Avatar
109jb
Will the instruments work on 5V constant DC, or will they only work on 5V pulsed DC??
