160tooth flywheel ...
Old May 8, 2009 | 05:16 AM
kalli's Avatar
kalli
Default 160tooth flywheel ...
Hi all,
maybe someone has an idea.
When I pulled my 289 I ordered a flywheel and clutch (10" dia) and 157tooth for the 302. I counted te teeth on old flywheel to 160. Thought I had it wrong and just ordered te 157tooth. The teeth were a bit gammy on the old one, but never gave problems.
So now I bolted it all up and it's perfectly fine. At the same time I ordered same clutch for friend (diaphragm, 10" McLeod) with a 1968 Mustang.
They pulled it apart just to find out it's 11" inch in there and they couldn't bolt the 10" clutch. I checked on engine and it's a 71 302 in his 68. we alwyas thatought it was a 289... His clutch was long style (not diaphragm). that migt be the reason onm why he couln't bolt the pressure plate.
So I said he can have my old flywheel no problem. So buddy of mine counted and had three other fellas counting. all5 agree: 160 tooth.
How is this possible?
We're not sure on what to order now. I thought if I give him my flywheel he just needs to get a different starter. Now I not really sure on what to get at all ?!
will I need to count the teeth on his old flywheel to see if his old starter bolts up?
Is there a way to determine the difference between the starters (tooth count)?
Will I need to buy a ring gear? will that even fit ?
Old May 8, 2009 | 06:10 AM
kalli's Avatar
kalli
i'm guessing that no matter what starter it will not engage if I have a 157toth flywheel where a 164 was given the fact that I'm keeping the same bellhousing ?!
Old May 8, 2009 | 11:34 AM
Randys66gt's Avatar
Randys66gt
Those 160 flywheels were on the 260's in falcons......... weird.
Old May 8, 2009 | 12:07 PM
kalli's Avatar
kalli
bellhousing is 6-bolt, so it's not original. But the car was 170ci 6cylinder. maybe they took the flywheel from original engine when they upgraded to the 289 V8.
makes sense. Anyway, since he has a bellhousing that was running with 164flywheel I guess he'll have to have that so that the starter can engage. My flywheel will be no good for him so.
Thanks for info with 160tooth. makes sense now.
CS2007
Jun 25, 2019 09:45 PM
CS2007
Florida Regional Chapter
Sep 29, 2015 12:06 PM
junior04
Sep 28, 2015 10:53 AM
Sep 10, 2015 08:39 PM
