Light Problem
Old May 8, 2009 | 10:56 AM
Eragon's Avatar
Eragon
Default Light Problem
I'm haveing a problem with my left rear light. The running light comes one with the three others when I pull the switch in the dash. But if I hit the brakes or the left turn signal or the hazards the left one won't come on? The right performs perfectly. Has anyone else had this problem or know how to fix it?
Old May 8, 2009 | 11:21 AM
Stepman's Avatar
Stepman
Have you checked the bulb? or for a loose or dirt socket?
Old May 8, 2009 | 11:29 AM
kalli's Avatar
kalli
if i remember correctly the 66 have as well only one dual-bulb.
easiest thing to check is just to swap the two rear bulbs.
if the prblem doesn't move with the bulb, then check if it behaves different with lights on or off
as in lights off, does brake light come on if you hit brakes?
then try lights on. do they come on or does everything switch off on that side
Old May 8, 2009 | 11:40 AM
Eragon's Avatar
Eragon
Thanks Stepman. I already checked that.
Yup, 66 has the dual bulb. I tried with three bulbs in it and even switched the whole light fixture (don't know another word for it. its the bucket that the lightbulb is in). On or off it doesn't make any difference.
Old May 8, 2009 | 12:38 PM
109jb's Avatar
109jb
Does the front turn signal come on at all, flashing or not??? If not, then you probably have a problem in the turn signal switch in the steering column. If the front turn signal comes on then you probably have a bad wire going to the rear of the car for the rear turn signal portion of that bulb.
Old May 8, 2009 | 01:04 PM
Eragon's Avatar
Eragon
All three other light work fine. I'll check the wires even though I couldn't find a bad one before. Thanks!
Old May 8, 2009 | 03:54 PM
109jb's Avatar
109jb
Probably still the turn signal switch in the column as everything has to run through that before they go to the lights. Here is what I am talking about.
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
1st 4 eyed fox
Aug 15, 2015 02:16 AM
philster0306
Aug 10, 2015 11:33 AM
