1971 302-164 tooth flywheel question
Old May 13, 2009 | 10:25 PM
67BullittCoupe's Avatar
67BullittCoupe
Default 1971 302-164 tooth flywheel question
my starter ate up my gears. and its progressed to the point that my car wont start 80% of the time.
so its time to fix it, i see that they have ring gears? is this all i need ($17) or do i need a whole new fly wheel
Old May 13, 2009 | 10:48 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you can replace just the gear, but a machine shop will need to install it
Old May 13, 2009 | 10:52 PM
67BullittCoupe
what exactly is required, i have use of an adequate shop, and ase techs. but looking to avoid labor costs.
Old May 13, 2009 | 11:27 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
they heat it up and knock the old ring off and heat up the new ring and press it on
Old May 14, 2009 | 04:08 AM
kalli's Avatar
kalli
+1. every machine shop should be able to do that for you
if you go for that make sure your starter and gear are good. might be wrong starter or something maybe ? something must have caused that problem
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
junior04
Sep 28, 2015 10:53 AM
