I had returned! with ac problems :(
Old May 19, 2009 | 01:01 PM
EmperorOfChicken's Avatar
EmperorOfChicken
Default I had returned! with ac problems :(
Hey you guys, I know its been a while been busy with school, work, and the other project, BUT IM BACK! and I have a question. My 65 mustang has factory AC, however recently there has been slippage on the pulley. the belts and all are spinning fine, however the pulley on the actual AC unit itself is spinning in spurts and fits, fast for a second, then not at all, then slow, then regular speed. what do I need to do to fix this? Im almost to the point where Im willing to ditch this AC compressor anyway for the turbo mounting location, but this texas summers gunna be hot...Thanks you guys!
Old May 19, 2009 | 01:04 PM
Starfury's Avatar
Starfury
Sounds like a clutch or clutch coil (which is part of the clutch), but could be an issue with the wiring to the clutch coil as well. Do you have a multimeter?
Old May 19, 2009 | 01:29 PM
2+2GT's Avatar
2+2GT
If you have the earlier type, with the commutator brushes on the back, you may not be getting proper contact due to dirt, wear or misalignment.
Old May 19, 2009 | 01:41 PM
urban_cowboy's Avatar
urban_cowboy
I know jack about A/C compressor pulleys, but that sounds like your problem, or at least something is causing it to not activate correctly. If you are in the San Antonio/Austin area, I can recommend a reputable A/C shop that works on my stuff. You are right, there is no way you can drive that thing from May to Oct without A/C!
Old May 19, 2009 | 03:11 PM
Starfury's Avatar
Starfury
Pfffft:P I drove my car (which has no a/c) for several years in 100-110F summers in central CA. Black vinyl and all.
Old May 19, 2009 | 03:38 PM
66JameStang's Avatar
66JameStang
Talking
You and your driving 100 miles to golf both ways with no AC in a 120 degree heat... and not just any heat, heat with a 110% humidity... not even breaking a sweat while waving at the girls in bikinis...
hahaha if the AC is there might as well use it...
Old May 19, 2009 | 04:05 PM
67t5ponycoupe's Avatar
67t5ponycoupe
There is a pressure switch in the system that turns on and off the compressor as needed. If you are running low on refrigerant the compressor will kick on and off. I say take it to the A/C shop and have them check it.
Old May 19, 2009 | 04:39 PM
Starfury's Avatar
Starfury
It should never be spinning slowly, relative to engine speed. That means the clutch is slipping.
Old May 19, 2009 | 07:32 PM
4reboy's Avatar
4reboy
nice to see you back
good luck with the fix, but if all else fails just take off the pulley and go open windows its true old school.
Old May 19, 2009 | 08:04 PM
67 evil eleanor's Avatar
67 evil eleanor
Welcome back!!!!!!!!!!!!!!! My thinking is its the clutch is k-put. If it starts slow then speeds up its slipping.
