Edelbrock questions
Old May 20, 2009 | 06:14 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default Edelbrock questions
I know own my first Edelbrock carb, not by choice. It was on the latest car I bought, 66 fastback. I have worked on some quadra jets about 20 years ago but that is my only eperience with this type of carb. It is a 1405 wich I have found out is a 600cfm. My question is this, at idle in gear I'm sure it is running too rich due to the cam that is in the engine. I don't know what cam is in there but it is very loppy at idle. I have made some adjustments, set the idle up and turned down the idle mixture. The vacuum gage in the car will be at 8 inches when I first pull up to a stop. If I sit there 2 seconds it will drop to 2 inches so I'm sure the rods are up and dumping fuel. It does have rods like a quadra jet right? If it was a Holley I know that I would need to change the power valve but it is a edelbrock so I'm a bit lost. Is there an adjustment that can be made to keep the rods down? Am I on the right track or just pissing up a tree. I'm thinking I need to trade it for a Holley so I know how to work on it. Any suggestions would help, if you know Edelbrocks.
Old May 20, 2009 | 06:31 PM
fakesnakes's Avatar
fakesnakes
Yu need the calibration kit and it comes with an assortment of springs to tune the metering rods:
http://store.summitracing.com/partde...5&autoview=sku
Old May 20, 2009 | 06:37 PM
2+2GT's Avatar
2+2GT
The Edelbrock™ is the reincarnation of the Carter AFB. Sounds like a minor amount of maintenance will give you a perfectly reliable setup, much more so than a leak-prone Holley.
Old May 20, 2009 | 06:41 PM
67t5ponycoupe
I guess I will try it but I am a Holley guy. It would not hurt for me to learn some about these Edelbrock's though, I guess.
Old May 20, 2009 | 06:42 PM
67t5ponycoupe
It is just weird, even the gas inlet is on the back of the carb. Kinda funky.
Old May 20, 2009 | 07:54 PM
cprstreetmachines's Avatar
cprstreetmachines
Even if the rods were up, it shouldn't matter. The carb won't be moving enough air to pull gas from it.Kinda like having 100 jetting in the front at idle. Doesn't matter. At that point, your not using the jets. Know what I mean ? Check your idle circuit for debris.
Old May 20, 2009 | 08:03 PM
67mustang302's Avatar
67mustang302
Or the idle speed setting is too high, and too much of the transfer slot is uncovered. What's the timing at idle? If it's got a big cam, it needs a bunch of idle timing to get the idle speed up, you don't wanna do it with just the curb idle speed screw.
Old May 20, 2009 | 08:04 PM
RHuckster's Avatar
RHuckster
It sounds like you have a big cam which @ idle will kill your manifold vacuum which will pull in the power valve circuit which makes things worse unless you have the proper setup in the carb. I had the same problem with my 68 Formula 400 firebird with a big cam running a Carter AFB.
Rick
Old May 20, 2009 | 08:26 PM
67t5ponycoupe
That is what I'm confused about, the power valve circuit. I thought the rods took care of that, is that true? Is there a power valve like in a Holley? I'm sure the power valve circuit is on because of low vacuum I'm just not sure how it works or how to fix it.
Old May 20, 2009 | 08:30 PM
shelbymustangdan's Avatar
shelbymustangdan
Here are some good links to have as a reference:
Owners Manual: http://www.edelbrock.com/automotive_...405_manual.pdf
Installation Instructions:
http://www.edelbrock.com/automotive_.../1000/1405.pdf
The owners manual will go into the metering rods, springs, etc., and some good diagrams of how they are changed.
I have had my challenges with my Edelbrock 1407 carb, which sits atop a strocked 408W, with the Edelbrock Performer RPM top end package. (cam, intake, heads, etc.) I'm sure it's not where I want it yet, but when time permits, I'll tinker with it more.
Hope this info helps you!
Dan
