Starter Solenoid?
Old May 23, 2009 | 07:11 PM
wumarshall82's Avatar
wumarshall82
Default Starter Solenoid?
I went to crank my car yesterday and nothing happened (almost like it was completely dead but its not). Eventually, after playing with the ignition for a few minutes it all of a sudden started to turn over and crank. This happened a while back but it just took a few seconds to get it turning over. Yesterday was the longest it took to get it turning over. Do you think my problem is the starter solenoid going bad?
Old May 23, 2009 | 07:22 PM
JamesW's Avatar
JamesW
That, or a loose connection in that general circuit. Clean all your contacts and whack that solenoid with a plastic screwdriver...
Old May 23, 2009 | 07:30 PM
1sweet65stang's Avatar
1sweet65stang
ya the connection from the solonoid to the starter go out sometimes mine did the same thing...also that wire dangling near the exhaust manifold is pretty unsafe as it can start an electrical fire i got a shorter wire myself
Old May 23, 2009 | 09:16 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Check to make sure the soleniod is securely fastened to the apron. It needs to grounded well.
Old May 24, 2009 | 01:54 PM
wumarshall82
Thanks guys.. i'll check it out.
Old May 25, 2009 | 06:17 AM
kalli's Avatar
kalli
if you drive automatic, maybe you have a problematic neutral safety switch?
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
logan409
Sep 26, 2015 07:43 PM
jaiidutch
Sep 14, 2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
daytooday
Sep 1, 2015 09:33 AM
