Anger and Frustration - Trouble starting at night - 68 coupe 302
Old May 25, 2009 | 09:52 PM
67mustang302's Avatar
67mustang302
Try making the idle a bit richer and then starting it at night.
Old May 26, 2009 | 03:31 AM
f0rdman's Avatar
f0rdman
ok, ill try that. thanks
Old May 26, 2009 | 05:00 AM
kalli's Avatar
kalli
wrong thread ..
Old May 26, 2009 | 05:09 AM
kalli's Avatar
kalli
Originally Posted by f0rdman
It backfires while I am cranking. It only does this at night when the engine is cold. When i initially turn the key it will feel like its starting and the fast idle will make it rev for a split second before it dies or as soon as i stop cranking it. thats with my foot just sitting on the gas pedal with the choke closed. If I push the gas all the way down it will eventually start and also be revved to like 3k.
that note: "make it rev for a split second ... as soon as i stop cranking it" makes me believe Kmatch has nailed it.
try running a wire from the 'I' post of your starter selonoid directly to your coil+ and see if that resolves it (this will feed your coil 12V+ while you crank)
Kalli
Old May 26, 2009 | 07:22 PM
f0rdman's Avatar
f0rdman
Kalli
I'll give it a try. I'm open to trying anything reasonable at this point. The problem is that I only have these problems when the engine is cold and has been sitting outside for 4+ hours in the street at night. I live in California so it's not too cold or damp outside at night. My buddy thinks the engine just isn't broken in yet. I think the carb or distributor might be defective.
djbigskrilla
Sep 20, 2022 01:04 AM
msavoia23
12
Jul 7, 2018 12:08 PM
67LimeCoupe
Nov 25, 2015 08:55 PM
prophotog
Aug 26, 2015 11:55 AM
chain
Aug 17, 2015 08:52 AM
