Weight
Old 05-25-2009, 08:22 PM
1slow67
ROTM Moderator
1slow67's Avatar
Default Weight
What are some ways to shave off some weight on the coupe? I plan on taking the rear seat out and making a seat delete. Aluminum door panels instead of the vinly style? What else?
1slow67 is offline
Old 05-25-2009, 08:33 PM
Starfury
Starfury's Avatar
Vinyl door panels hardly weigh anything; I wouldn't worry about those much.
If you're serious about it:
Spare tire
Insulation (weighs a lot more than you'd think)
Interior trim panels
Exterior trim pieces
Hood and front valence (switch to fiberglass)
Glove box
Heads/intake (switch to aluminum)
Power brake booster
Pony grille insert
Power steering setup
A/C system
Spindles and suspension (switch to TCP forged w/coilovers)
Radio
All I have for now.
All that said, you're probably going to see more improvement from gears, tires, and a good suspension than you will from basic weight loss stuff.
Starfury is offline
Old 05-25-2009, 08:47 PM
stangtjk
stangtjk's Avatar
Remove all the window regulators and glass and replace it with lexan.
stangtjk is offline
Old 05-25-2009, 08:50 PM
1slow67
ROTM Moderator
1slow67's Avatar
I have new gears since I upgraded to 5 lug. I went from 3.21 to 3.00 gears. I'm taking out the spare, I'll take off the pony corral on the front, I am trying to figure out how to take off my front bumper(and make it look good), don't have A/C PS or PB, thinking about moving the radio, I'm going to lower it some more to help with the center of gravity, I was thinking about getting some roller perches.
1slow67 is offline
Old 05-25-2009, 08:51 PM
1slow67
ROTM Moderator
1slow67's Avatar
Don't think my parents would allow that unfortunately.
1slow67 is offline
Old 05-25-2009, 09:06 PM
Starfury
Starfury's Avatar
Good. It's not DOT legal, as far as I know. Works for a race car, which doesn't have side windows, but you should have glass in a real car. You need to be able to break out of the car in an emergency, and you aren't going to break the lexan.
3.22 to 3.00 gears is the wrong way for performance. I'm running 3.25's and they're barely enough to keep my motor happy.
Starfury is offline
Old 05-25-2009, 09:09 PM
racin66coupe
racin66coupe's Avatar
why are you trying to shave weight? i thought it was a show car?
racin66coupe is offline
Old 05-25-2009, 09:20 PM
1slow67
ROTM Moderator
1slow67's Avatar
It is a show car, but I would like to have some fun every now and then. Just for fun do some racing with it.
1slow67 is offline
Old 05-25-2009, 09:24 PM
1slow67
ROTM Moderator
1slow67's Avatar
I know it isn't good for it. I plan on upgrading to 3.55s or 3.73s ASAP. Once my grandfather and dad told me I couldn't launch it as hard as I usually do I knew the gears would have to go.
1slow67 is offline
Old 05-25-2009, 09:30 PM
Starfury
Starfury's Avatar
Like I said, true weight savings are not for a 'just for fun' car. You're going to remove a lot of amenities that you'll like on a street car before you ever see a noticable performance improvement.
You're much better off with aluminum top end, gears, 5sp, disc brakes, and suspension upgrades.
Starfury is offline
Quick Reply: Weight
