Testing a Starter
Old May 25, 2009 | 08:52 PM
mstg007's Avatar
mstg007
Default Testing a Starter
Is there a method to see if your starter is working correctly? I have a starter that seems to get heated up and will not crank. But After the engine cools for 10 mins or so, The engine will crank over.
Strange.
Old May 25, 2009 | 09:04 PM
JamesW's Avatar
JamesW
Take it to Autozone or such and have them run a test. It checks for load/capacity
Old May 25, 2009 | 09:31 PM
mstg007's Avatar
mstg007
Will do. Thanks for the feedback.
Old May 25, 2009 | 10:09 PM
2+2GT's Avatar
2+2GT
Best to load check it in the car. I've seen them work fine on the bench even when shot.
Old May 25, 2009 | 10:19 PM
Starfury's Avatar
Starfury
Takes an informed person to work a bench tester. There's more to it than 'good' or 'bad.' I can read the waveform to see if the brushes are failing, but most people can't.
Old May 26, 2009 | 01:03 AM
nba1341's Avatar
nba1341
did you make sure your starter is not loose?
and did you bang on it a little?
Old May 26, 2009 | 08:54 AM
mstg007's Avatar
mstg007
I did. I tightened the bolts and the nut to the power shaft are is good. After it cools down its will fire back up
Dathan
Oct 5, 2015 05:52 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
logan409
Sep 26, 2015 07:43 PM
