Gas venting from fuel pump
Old May 26, 2009 | 10:04 AM
StangX2's Avatar
StangX2
Default Gas venting from fuel pump
Hey folks,
My 67 is blowing a lot of gas out of the vent in the fuel pump. Car has just been put back on the road but was not doing this with first 50mi. Mechanic "adjusted" carb for slight hesitation recently. Fuel pump was fairly new before car was parked. Car runs normal.
I'm thinking I have a carb problem not a fuel pump problem. Any advice where to start looking.
Thanks,
StangX2
Old May 26, 2009 | 10:40 AM
cprstreetmachines's Avatar
cprstreetmachines
You mean your carb is blowing gas out the vent tube ? That's either a needle and seat problem or a fuel pump with PSI too high.
Old May 26, 2009 | 10:57 AM
StangX2's Avatar
StangX2
cpr,
thanks for the reply, the gas is coming out of a small vent in the top of the fuel pump. The manual says something about this preventing the fuel pump from building up too much pressure at the carb.
StangX2
Old May 26, 2009 | 11:47 AM
blue66mustang's Avatar
blue66mustang
I would think it has a hole in the diaphragm of the fuel pump. I shouldn’t leak fuel.
Old May 26, 2009 | 11:52 AM
jcoby's Avatar
jcoby
if it really is coming out of the fuel pump, it sounds like you need a new fuel pump or to rebuild. i've never seen or heard of a fuel system that was designed to leak fuel.
what kind of fuel pump? if mechanical, the diaphragm probably became brittle while the car was parked. after enough time it developed a split and is now leaking.
Old May 26, 2009 | 11:54 AM
jcoby's Avatar
jcoby
if you leak fuel you've got bigger problems! gas tastes awful.
Old May 26, 2009 | 01:02 PM
fakesnakes's Avatar
fakesnakes
Disconnect the fuel line from the carb and direct it into a safe container. Disconnect your coil so the car won't start. Crank the engine so the fuel pump pumps fuel into the container and watch the pump for leaks. I think you need a new pump.
Old May 26, 2009 | 02:10 PM
JMD's Avatar
JMD
If the pump itself LEAKS ANYWHERE,,,, EVER, it is late for the trash can....
The pump is trash.
Old May 27, 2009 | 08:44 AM
blue66mustang
LOL...yeah I don't leak fuel. Maybe GAS but not FUEL.
Old May 27, 2009 | 01:05 PM
StangX2's Avatar
StangX2
Thanks for the advice, I can't help you with the personal problem of leaking fuel or gas. But I will be replacing my fuel pump.
Thanks,
StangX2
