timing
Old May 27, 2009 | 08:42 PM
65Rocky's Avatar
65Rocky
Default timing
What is the timing set at, I put a 5.0 and carb with crane dizy,
run but no power.
65 5.0 aod 9in 3.89
Old May 27, 2009 | 08:48 PM
MIL1ION's Avatar
MIL1ION
Old May 27, 2009 | 09:19 PM
65Rocky's Avatar
65Rocky
thanks, but I have a 1990 5.0 is it the same? running 11 at idle
Old May 27, 2009 | 11:16 PM
67mustang302's Avatar
67mustang302
Try 14 at idle and around 34-36 total.
Old May 28, 2009 | 08:51 AM
hotrod351's Avatar
hotrod351
the old rule of thumb = advance it until it starts to ping going uphill, then back it off a few degrees.
Old May 28, 2009 | 11:26 AM
65Rocky's Avatar
65Rocky
I will give it a try, Also the AOD shifts to early,
I have moved the TV cable in and out but can not find the sweet spot.
**Will the use of the 289 timing cover and a new HB with three sets of numbers work, I use the outer most nunbers that seems to line up with the pointer.**
Old May 28, 2009 | 12:36 PM
MIL1ION's Avatar
MIL1ION
Your..... 65 5.0
was misleading then
Best just to post what you have so it is easy to understand
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
