Octane levels
Old Jun 4, 2009 | 04:33 PM
CyprusMustang's Avatar
CyprusMustang
Default Octane levels
Hi guys who knows what octane is supposed to be used for the ford 302 1969 engine?
Old Jun 4, 2009 | 06:11 PM
scootchu's Avatar
scootchu
http://www.carmemories.com/cgi-bin/v...erience_id=232
My guess is Premium and that would be 93-94 Octane at most US gas stations
Old Jun 4, 2009 | 10:51 PM
67mustang302's Avatar
67mustang302
Which 302? Chances are it'll run on crap low octane fuel. The engines of that day in most cases were modest compression and had poor cylinder filling, so detonation isn't really an issue, provided it's tuned right.
Old Jun 4, 2009 | 11:03 PM
knuckless's Avatar
knuckless
in my original 1968 manual my 289 needs 93 octane...and that was regular back in the day...so basically you need something around that. ive found that when i run my 289 on 87 it doesnt run as strongly as with higher octane
Old Jun 5, 2009 | 12:55 AM
67mustang302
You're not going to feel the car running worse on lower octane fuel unless it either detonates, or if it's EFI and the computer is pulling timing. Fuel quality matters a lot more. Depending on where you get fuel, the higher octane usually has better additive packages, so it tends to be cleaner. Higher octane fuel will make your car run slower though(but the difference between 87 and 93 may only be noticed at the track), higher octane fuel has more resistance to ignition and burns slower.
In extreme cases too much octane can actually destroy an engine. Running 115 in a 9:1 engine for example can result in the fuel not igniting properly and not burning completely, and you can get liquid fuel up in the ring lands and unseat the rings, which results in flutter and fubars the rings and cylinder walls. Plus it acts as a solvent and washes oil off the cylinder walls.
Old Jun 5, 2009 | 09:43 AM
hotrod351's Avatar
hotrod351
my wifes 70, 302, has to run prem. and in the summer, temps hers well above 100 degrees, and the ac on she adds octane booster.
Old Jun 5, 2009 | 02:31 PM
jspagna1's Avatar
jspagna1
I always run 93 octane when I need gas in a pinch. What I try to do is run 1/2 tank 93 octane and 1/2 tank CAM II. I know a lot of car guys in my area do that since CAM II is so friggin expensive.
Old Jun 6, 2009 | 01:46 PM
cprstreetmachines's Avatar
cprstreetmachines
Run as low as the engine will tolerate.
Old Jun 6, 2009 | 06:12 PM
Scott H.'s Avatar
Scott H.
Last edited by Scott H.; Jan 23, 2010 at 03:24 PM. Reason: added the wiki Octane article.
Old Jun 6, 2009 | 09:51 PM
90RunnerRed's Avatar
90RunnerRed
Originally Posted by Scott H.
In the "old days" when these cars were built gasoline was rated at Research Octane Number (RON), not Motor Octane number (MON) which is much lower.
Now the Octane rating at the pump is an average of the two (RON+MON)/2, and is known as Pump Octane Number (PON).
This should be on a sticker on the gas pump at your local station.
IIRC, PON relates to about 3 points off RON, but a quick google search on the above terms will get you the actual percentages.
http://en.wikipedia.org/wiki/Octane_rating
Wow, you learn something everyday, had no idea.....
Below seems to be a decent article comparing the numbers:
http://www.btinternet.com/~madmole/R...RONMONPON.html
