Heads and cam instead of crate 347!!
i posted a thread the other day about finding the best place for a crate 347 stroker for my 66 fastback. there's no way the wife is going to sanction 6k or 7k when the stock 302 i have still runs perfect. so now i have decided to do the heads and cam upgrade instead. my question is what combo will give me what i want??? what i want-- a thumpy engine thats dependable and makes HP in the 330 to 350 range.
yep afr 165's or even better twisted wedge heads, I'm wary on hyd cams anymore, I'd convert to a hyd roller and run like an xe 274hr for a little thump. I have seen a dyno test on a 5.0, 274hr, 10.1 comp,tw heads, air gap int and demon 650 make right around 400 hp. I think it was 428hp on westec's "magic dyno and 400 hp with afr 165's, stock 5.0 cam, 1.7 rockers and the above, I dont quite believe those numbers but I'm sure 350-375 hp is very dooable. The roller cam wont get flat lobes, will idle better and give a broader range and more lift than a comparable hyd cam. The TW heads will give a bit more power than the 165's and cheaper. The xe 274 has the same ramps as the xe 262 so bottom end will be about the same but past 4000 rpm power will increase quite a bit.
I'd suggest a roller cam upgrade from Comp Cams to start with. Its one of their Retro-Fit kits. Order the cam, lifters and timing chain kit. Your looking at about 550 - 575 with the hold down kit. Instead of ordering new aluminum heads at 1200+ go find a set of 351w heads and gasket match them to a new RPM intake. I've got a set but I'm sure you could find a set on the west coast cheaper then shipping from the east coast. The larger 351w heads ported out would give your a huge performance increase over the stock 289/302 heads and save you money.
Edelbrock has excellent quality as well. While you're at it, you might as well spend the bones for a good set of pistons, like Mahles. They'll be way stronger, weigh less, and with a good ring pack have reduced friction and wear. The valve reliefs will give some extra space if you don't have any right now. Might as well just spend the money on a custom cam setup, since it's not that much more. Edelbrock or TFS heads are decent. I have AFR 165's on mine, for some reason lately people have been getting on the "hate AFR" bandwagon(not talking about this thread, just in general). They're all good heads that will perform well, so you might as well get whatever is cheapest. Edelbrock heads are very good quality. If you have the gears in the differential, then you could put good pistons in and just do the Edelbrock RPM top end kit, saves the trouble of having to buy stuff separately.
the 351W heads is probably the cheapest option to wake up a 302 but I wouldn't be happy with the reduced compression.
i have those edelbrocks rpms on my 302 and with a matching cam you should be easy in the 300+ range
