Electrical Help - Blinkers...
Old Jun 10, 2009 | 03:11 PM
Jforte13's Avatar
Jforte13
Default Electrical Help - Blinkers...
Hey guys, need help where to start on investigating my electrical issues. My blinkers are not working. My brake lights DO work though, my dash lights work, and my headlights work.......what are the possible problems minus the obvious bulb and fuse? Thanks any help woudl be GREATLY appreciated...
Old Jun 10, 2009 | 03:16 PM
boeing747arowair's Avatar
boeing747arowair
you might to check the blinker switch assembly behind the steering wheel i know mine was torn up!
Old Jun 10, 2009 | 08:50 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Flasher?
Old Jun 10, 2009 | 09:10 PM
67mustang302's Avatar
67mustang302
Yeah, try the flasher first, they go out from time to time. Then check the switch in the column.
Old Jun 10, 2009 | 09:56 PM
knuckless's Avatar
knuckless
check the connection from the bottom of the steering column. i know when i bump mine sometimes the blinkers and horn dont work.
Old Jun 14, 2009 | 07:52 PM
Jforte13's Avatar
Jforte13
Hey Guys, thanks for your input, i have been fiddling with things over the weekend and I never thought to try the hazards, but I did try them and they work perfect! So if the hazards work perfect, the problem has to be pretty easy to find since they are both controlled with mostly similar parts...what do you guys think it is now knowing that the hazards work?
THANKS!!
Old Jun 14, 2009 | 08:42 PM
67mustang302
Probably the flasher, there's a different flasher for the hazards and turn indicators, try taking the one from the hazards and putting it on the turn signal location, if the turn signals work then it's the flasher, they're like $2.50 at the auto parts store I think.
Old Jun 14, 2009 | 09:32 PM
Jforte13's Avatar
Jforte13
Thank you so much, I will give this a shot!
Old Jun 14, 2009 | 10:52 PM
Jforte13's Avatar
Jforte13
Can't find the flasher unit....I just spent 15 minutes upside down poking around...am I blind, or is it hidden???
Old Jun 14, 2009 | 11:08 PM
67mustang302
You have to really reach up under the dash, factory location is on the brace behind the dash, sort of tucked up on it in retainer clips. You almost have to be a contortionist to get to it.
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
allenmaty
Sep 24, 2015 09:17 AM
uberstang1
Sep 20, 2015 06:42 PM
TfcCDR
Sep 14, 2015 12:08 PM
