New Ford guy needs info on engine swap...
Old Jun 12, 2009 | 08:02 PM
lawman65's Avatar
lawman65
Default New Ford guy needs info on engine swap...
I have a 65 coupe and have an oportunity to buy a complete 1990 5.0 roller engine w/65K miles on it. I currently have a carburated early 302 in the car that has a distributor w/pertronics ? installed. I dont want to do an EFI install, I just want to use the stock 5.0 block w/new AFR 165 heads, roller 1.6 rockers and a mild cam. I plan on using my existing carb and whatever else will match up. My car also has a four speed but not sure which one, definitely not a new tranny. I believe I will need a new intake as I'm not sure the stock intake will work with a carb. Also not sure if water pump inlet/outlet will work with my current radiator w/both in/out on the pass. side. Can I use the existing motor mounts ? Can anyone tell me what it will take to use the 5.0 block/parts to complete the swap? Thanks.
Old Jun 12, 2009 | 08:11 PM
67mustang302's Avatar
67mustang302
The timing cover won't have provision for a mechanical fuel pump, and the cam gear won't have the fuel pump eccentric, you can stick an early model water pump on it, maounts are the same, but you'll need a mechanical clutch linkage adapter since the later blocks don't have the provision for it. Or you could convert to a hydraulic clutch setup. Just use a standard 289/302 carb intake.
Old Jun 12, 2009 | 08:58 PM
lawman65's Avatar
lawman65
Default ok thanks!
Thanks for the info! So let me get this right, I would need to install an electric fuel pump, install a clutch linkage adjuster (any idea where to purchase?), use older style water pump, and I can use or re-use my current aftermarket intake. Any idea on motor mounts? Will I have to change them or use what I have? Again, thanks for the help!
Old Jun 12, 2009 | 09:20 PM
2+2GT's Avatar
2+2GT
Use your current distributor, make sure the dist. gear is the right one for the cam you get.
If you have a carb intake now it will work.
Sure. Use the timing cover, water pump, and fuel pump you have now. You'll need a new 50 oz. conversion harmonic balancer if your old 302 is old enough to be the 28 oz. type, and has 3-bolts holding the pulley on. Don't forget to put the fuel pump eccentric on the new engine' camshaft, or there'll be nothing to operate your pump.
You betcha.
If your 302 is the 28 oz. type, you'll need a 50 oz flywheel, too.
You'll need a bracket to attach the equalizer to the block. Common conversion item.
No! Read my above- you already have most of what you need.
Old Jun 12, 2009 | 09:22 PM
lawman65's Avatar
lawman65
Default oops
Didn't see the motor mount info at first, sorry. Can I use the flex plate and damper from the old 302 or use what is on the 5.0 depending on if it was in a manual tranny car? Think the newer engine has a different damper..28 oz. versus 50 oz on older engine. Thanks!
Old Jun 12, 2009 | 09:26 PM
lawman65's Avatar
lawman65
wow, you guys are fast with the info. I cant reply quick enough.. lol Thanks for all the help. It doesnt seem that difficult of a swap so I'll most likely purchase the engine.
Old Jun 12, 2009 | 09:32 PM
lawman65's Avatar
lawman65
Is there an online business I can contact for the specific conversion parts I would need? Mustangsplus? Mustangdepot? Virginiaclassicmustangs?
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
inyadreems
Aug 21, 2015 09:10 AM
Stilz
Aug 19, 2015 06:17 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
