problem with new distributor
Old Jun 13, 2009 | 01:59 PM
gibsonxplayer88's Avatar
gibsonxplayer88
Exclamation problem with new distributor
so i ordered one of the MDS ready to run kits that comes with the a pro billet distributor, blaster 2 coil, and wires. spent all day putting it together for it all not to work.
i made sure the coil in the distributor was lined up in the same spot over the same plug. but is it possible that when i put the new distributor in i could have changed the position of the revolution when i turned the oil pump slightly to get the distributor shaft all the way down?
as of right now, if i hold the gas when i start it the car like sputters and then starts until i let off the gas.
any ideas?
Old Jun 13, 2009 | 02:50 PM
Gun Jam's Avatar
Gun Jam
when installing the dizzy the tooth on the dizzy gear may have rotated when installing and is now one tooth off of the drive gear.
Further more attempting to set timing without a light will yield less than optimal results but you should get it to run a bit better than that.
Try removing the dizzy again and making sure the rotor is dead center on 1 once the dizzy is fully seated.
Further more make sure piston 1 is TDC...
-Gun
Old Jun 13, 2009 | 04:08 PM
gibsonxplayer88
how can i find out if its tdc?
Old Jun 13, 2009 | 05:09 PM
fakesnakes's Avatar
fakesnakes
Remove #1 spark plug, put your thumb over the hole, and rotate the engine by hand until you feel air escaping. Continue rotating the engine until the balancer is at zero. On a carb car, you can not be off a tooth. Simply turn the distributor until the rotor is just past the #1 wire position on the cap. Start the car and set the base timing.
Old Jun 13, 2009 | 05:41 PM
kalli's Avatar
kalli
you say the car is actually starting and stalls when you let off the gas. have someone start the car while you turn the duistributor clockwise and anticlockwise to get it into the ballpark. but in the end you will have to use a timing light to get it right
Old Jun 13, 2009 | 06:48 PM
Starfury's Avatar
Starfury
At least it's running right now, but you absolutely need a timing light to get it moving.
Old Jun 14, 2009 | 12:51 PM
gibsonxplayer88
see but my car doesn't have the belt with the timing strip on it. so how would i get the timing right without it?
Old Jun 14, 2009 | 12:59 PM
kalli's Avatar
kalli
option a) timing light with advance so you set th etiming light to the degrees you want and adjust for TDC against the pointer
option b) buy a timing strip that you can tape to the balancer. For this you need to know the diamater of the balancer. they're only a few follar fifty
Old Jun 14, 2009 | 01:07 PM
Gun Jam's Avatar
Gun Jam
option C) Check the damper wheel (the thing bolted to the crank shaft) for timing marks. try taking light sandpaper like wet/dry 800 grit and using wet to gently remove any grime or rust that maybe covering the timing marks on the outside edge (or even perhaps the face) of the damper wheel.
They should be there check carefully paint can be used to highlight the numbers after you find them....
Note: timing marks are not found on the belt in this application.
-Gun
Old Jun 14, 2009 | 01:08 PM
gibsonxplayer88
and there is a mark on the balancer that has a little notch that says TDC next to it, is that the 0 mark im looking for?
