Hooker Headers
Old Jun 16, 2009 | 08:01 PM
Flash70's Avatar
Flash70
Default Hooker Headers
Got my hooker headers delivered and for some reason they do not fit !! The transmission bellhousing seems to get in the way of them being installed correctly... Is this a typical problem when ordering headers online? Can I have a shop fix it somehow? Maybe by cutting and rewelding the headers to fit properly??
Pretty disappointed about this
Old Jun 17, 2009 | 03:41 PM
palerider's Avatar
palerider
Sure you got the right headers for your application. I've got hookers on my 70 with 302 C4 and no problems. I order 99% of my parts online - as long as you get right part # for your set up - should be okay other than needing to do a drop of steering linkage.
Old Jun 17, 2009 | 03:47 PM
Toddman0025's Avatar
Toddman0025
Have a set on my 351c, tight fit but they're in there.
Old Jun 17, 2009 | 04:41 PM
truplayr251's Avatar
truplayr251
Im not sure about your 70, but in my 65 with the AOD installed i was unable to put my hooker headers in until i jacked up the motor and slid them in. Then i was simply able to put the motor back down and bolt up the headers.
Old Jun 17, 2009 | 08:13 PM
Flash70's Avatar
Flash70
Yes I tried putting them on with the engine out of the car first. A small round loop(?) on the bellhousing is in the way on one side. The loop seems to server no purpose, meaning there is no bolt holes on it or anything of the sort. Should I cut it off? haha.
I got the long pipe headers not the shortys maybe thats why...
Old Jun 17, 2009 | 09:13 PM
pinboy122's Avatar
pinboy122
i had a similar deal,i just used a grinder to remove the offending material.take your time,mark it out carefully.it took me all of about 5 min.
Old Jun 18, 2009 | 12:51 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
do you have a large or small bellhousing on your tranny?? some long tubes are not for use with the large bellhousings(164tooth) and only for the 157
Old Jun 18, 2009 | 10:19 AM
Flash70's Avatar
Flash70
By tooth are you referring to my flywheel? I believe this is a large bellhousing in that case. I will see what I can come up with. Lots of work to do today
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
junior04
Sep 28, 2015 10:53 AM
JT76
Sep 20, 2015 11:32 AM
BrantleyS550
Sep 14, 2015 04:18 PM
