surface rust, underneath
Old Jun 22, 2009 | 10:53 AM
wareagle's Avatar
wareagle
Default surface rust, underneath
i am in the process of replacing the floors, after figuring out where i was going to cut out the old floor, i thought it would be good idea to look under to make sure that i wouldnt cut thru anything important, like the gas line or brake line, etc... my question: what to do to all the surface rust under the car, how to get to all of it? this is not a frame off resto, what to do?
next question, after I weld in the new floors from the inside, i plan on overlapping them a quarter inch or so. What do i do on the underside, do I weld from below as well, or just apply seam sealer, or some undercoating stuff? thanks for the help
Old Jun 22, 2009 | 10:59 AM
2+2GT's Avatar
2+2GT
Use wire brush and muleskinner to remove the rust.
Lap weld? I did my floors that way. If the big one-piece had been available then, I'd have used it.
I left 1/4 - 1/2 overlap, and after I was done, I went underneath with an air chisel and peeled off the excess, back to the weld.
Old Jun 22, 2009 | 12:44 PM
SJs 66coupe's Avatar
SJs 66coupe
For the surface rust, I'd wire brush what you can off then por 15 it and put a coat of undercoat or bed liner on top of that.
Old Jun 22, 2009 | 01:40 PM
jcoby's Avatar
jcoby
what is a muleskinner?
Old Jun 22, 2009 | 01:46 PM
TexasAxMan's Avatar
TexasAxMan
Why would you put POR15 and then bed liner???
Old Jun 22, 2009 | 03:24 PM
2+2GT's Avatar
2+2GT
It's a wire wheel encased in hard rubber or plastic.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
b8checker
Oct 8, 2015 12:55 PM
Oct 1, 2015 09:29 AM
b8checker
Sep 30, 2015 07:11 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
