new front end
Old Jun 30, 2005 | 04:21 AM
v6stangracer's Avatar
v6stangracer
Default new front end
so after removal of the fenders of my 66 and further review, plus the help of a friend, ive come to the conclusion that the front end of my car is all new, its really flimsy in parts, my buddy who is an auto body guy said its pretty common to replace the front end with aftermarket stuff from over seas, and its not strong enough by itself, anyone know what im talking about or have any imput?
Old Jul 2, 2005 | 04:23 PM
chech626's Avatar
chech626
Default RE: new front end
a buddy of mine had the same problem he went restomod with the mustang 2 conversion and replaced everything else with stronger parts and now has 427 sitin under the hood
but im not sure what you want to do with yours restore it or restomod it
Old Jul 2, 2005 | 06:47 PM
dodgestang's Avatar
dodgestang
I'm confused...you removed your fenders to look at your front end? (front end to me is defined as suspension/steering/braking/etc)?
Old Jul 2, 2005 | 09:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
I agree with Nick. What front end parts are you talking about? You don't have to remove fenders to take a look at your front end parts. What exact parts are you talking about?
Old Jul 3, 2005 | 01:26 AM
v6stangracer
sorry ill be more specific, the core support, and two panels runnin down the sides of the engine bay inside the fender, two guys at work called it the unibody although ive never heard that before then, o and btw, i measured from one corner of the engine bay then the same on the other sides and it turns out its not all square, do u think it will be alright its under an inch of difference, tomarrow my dads gonna check it out with me tho
Old Jul 3, 2005 | 10:25 AM
dodgestang's Avatar
dodgestang
I under stand now.
Keep in mind all the steel is flimsy 'by itself' its the tying it all together in the unibody that gives it strength.
Plenty of cars are rebuilt using oversea repro steel and are just fine. The biggest problem has always been fit, but it seems like someone has already installed the parts and done the fitting.
Having the engine compartment square isn't that big of a deal. The important measurement is at the frame rails, measure corner to corner in an 'x' from driver side front rail to passenger side rear rail, and then flip. These measurements should be within a very close tolerance of each other and it will tell you if the car is straight.
Old Jul 4, 2005 | 12:54 AM
ivanr77's Avatar
ivanr77
I've never thought of that. I'm going to check my own frame out tomorrow.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
the5
Sep 19, 2015 06:13 PM
Sparks_88
Sep 8, 2015 01:06 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
