Help Decoding
Old Jun 28, 2009 | 09:37 PM
Houndstooth's Avatar
Houndstooth
Default Help Decoding
I'm hoping someone can help me decode the casting code on my block. I found the code when I pulled the starter and have been trying to figure out what it means. Everything I am seeing says that the first or second digit is supposed to be a letter which corresponds to the year. I triple checked my code and it is 75ZY-6015-AA. Does this mean anything to anyone or can you tell me where to find out what it means?
Old Jun 28, 2009 | 09:55 PM
1slow67's Avatar
1slow67
ROTM Moderator
It is a mexican block 302 from what I find.
Old Jun 28, 2009 | 10:27 PM
Houndstooth
How did you find that out? What does that mean, are these replacement motors or did they put Mexican blocks in from the factory?
Old Jun 28, 2009 | 11:22 PM
1slow67's Avatar
1slow67
ROTM Moderator
I searched "75ZY-6015-AA casting number" on google. You have to pick the right site though.
According to some sites it is supposed to be stronger than the regular block. I don't know if they put them in stock though.
Example: http://www.fordmuscle.com/forums/all...lp-needed.html
Old Jun 29, 2009 | 07:23 AM
kalli's Avatar
kalli
i'd be delighted if I asked what block and someone told me Mexican :-)
Old Jun 29, 2009 | 08:25 PM
Houndstooth
Thanks for the help. There seems to be some spirited debate on whether or not the Mexican block is actually stronger. I saw some pictures and it looks like the main caps are definitely bigger. From what I can tell though they only came in trucks and vans (don't quote me on that though).
Old Jun 30, 2009 | 04:51 AM
kalli's Avatar
kalli
they are stronger. no debate
Old Jun 30, 2009 | 03:13 PM
Stangman70's Avatar
Stangman70
the mexican blocks used different materials in the casting process. more nickel content i believe which made for a stronger block.
Old Jul 1, 2009 | 12:33 AM
Houndstooth
Some people say that's true and others say it's a myth, I'll go with true. Sadly I don't know much about the motor as it was rebuilt before I got it. It sounds like it has a mild cam. I know the Boss 302 had 351C heads. Can I put these heads on my 302 without clearance issues or are there better heads? It already has headers, a Weiand intake, and Holley 600cfm carb, what else can I do?
I'd like it to be streetable but make the occasional trip to the Woodburn drags.
Jonnyyuma
Oct 4, 2006 02:13 PM
chillininnh
Apr 1, 2006 11:44 PM
gumbyrmw
Mar 27, 2006 09:31 PM
ironh19
Mar 2, 2005 11:42 PM
67aquafastback
Nov 17, 2003 11:59 PM
